need help with my teggy!
well i think my alternator is done for cause today the car wouldnt start and after i got it jumped i would push the break and it would bog down until it shut off...... so need to know, is it the alternator or could it be something else. and does anyone know where i can get one or anyone have one that i could get pretty quick cause i am to start a new job soon.... come on guys help me out!
TR's drive my car more than 2500 miles in less than a month crew member #01
Try jumping hte car and then while its running disconnect your battery and if the car shuts off shortly after then your alternator not producing charge. good luck.....Best Regards...FrankensteinMan23
The Dr. Is In! D16 on Crack Build Thread
TESTING
Voltage Test
Make sure the engine is OFF, and turn the headlights on for 15–20 seconds to remove any surface charge from the battery.
Using a DVOM set to volts DC, probe across the battery terminals.
Measure the battery voltage.
Write down the voltage reading and proceed to the next test.
No-Load Test
Connect a tachometer to the engine.
CAUTION
Ensure that the transmission is in Park and the emergency brake is set. Blocking a wheel is optional and an added safety measure.
Turn off all electrical loads (radio, blower motor, wipers, etc.)
Start the engine and increase engine speed to approximately 1500 rpm.
Measure the voltage reading at the battery with the engine holding a steady 1500 rpm. Voltage should have raised at least 0.5 volts, but no more than 2.5 volts.
If the voltage does not go up more than 0.5 volts, the alternator is not charging. If the voltage goes up more than 2.5 volts, the alternator is overcharging.
NOTE: Usually under and overcharging is caused by a defective alternator, or its related parts (regulator), and replacement will fix the problem; however, faulty wiring and other problems can cause the charging system to malfunction. Further testing, which is not covered by this book, will reveal the exact component failure. Many automotive parts stores have alternator bench testers available for use by customers. An alternator bench test is the most definitive way to determine the condition of your alternator.
If the voltage is within specifications, proceed to the next test.
Load Test
With the engine running, turn on the blower motor and the high beams ( or other electrical accessories to place a load on the charging system).
Increase and hold engine speed to 2000 rpm.
Measure the voltage reading at the battery.
The voltage should increase at least 0.5 volts from the voltage test. If the voltage does not meet specifications, the charging system is malfunctioning.
Voltage Test
No-Load Test
CAUTION
Load Test
thanks guys. yea it was the alternator and i am replacing it tomorrow... so thanks again to everyone and nice details dr latino!
