smokin problems
Old Nov 16, 2004 | 04:36 PM
crazybajapanti's Avatar
DJ Onda
Default smokin problems
have a 90' accord just gave it a all around tune up and now its smokin like crazy. it has new gaskets all around that i did like rwo months ago so no leaks, so guys tell me wat you think? thanx
Dis be dat Nigga Manny
"I aint a killer but dont push me, revenge is like the sweetest joy next to getting pu*sy"/- (Tupac Words)
"There is no betta place than tha Chi, where i ride n stay high!"/- Mannys Words)
Old Nov 16, 2004 | 05:24 PM
integrakev78's Avatar
(Torqueless Wonder)
what color is the smoke?Does it smoke all the time or does it smoke when you start it up or at high rpms when you shift if it does it all the time I would say rings or headgasket or if it does it when you start it up it could be valve seals if it does it at high rpms it could be running rich it really depends on what color the smoke is
Old Nov 16, 2004 | 05:42 PM
vtec accord's Avatar
forsale
if its black smoke it is fine it is runnin rich if it is blue it is oil and that is more than likelyvalve seals , also how many miles do you have on it my old mmotor in my 95 did it and i had no oil leaks it just burne and itt was the valve seals
Old Nov 16, 2004 | 06:33 PM
MacGruber's Avatar
MaDe Of MoNeY
first thing do a compression test then a leak down.
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old Nov 18, 2004 | 01:42 PM
DOHC16CRX's Avatar
CARPET GUY
i would say valve seals also..thats the problem most of the time
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
