Dry nitrous kit and p28 ecu open loop
Old Nov 11, 2004 | 04:14 PM
VTECpower2000's Avatar
Default Dry nitrous kit and p28 ecu open loop
Hello,
I got a 94 gsr with boltons and p28 ecu with Kenjis allmotor program running open loop.
My question is can I run a nitrous dry kit with that ecu running open loop?
My mods,
Comp cams stage2
Skunk2 manifold
Fields vtec controller
B&N FPR
AEM cai 3"
Crane hi6 box w/coil
Skunk2 cam spokets
Kenjis p28 ecu Allmotor program
DC JDM 4-1 header
Test pipe
Apexi World sport catback
68mm TB
Old Nov 11, 2004 | 05:35 PM
99B16Si's Avatar
most dry nitrous kits are TPS activated and when your at WOT youre in open loop anyway. why is your closed loop disabled?
Old Nov 11, 2004 | 06:32 PM
n20teg's Avatar
Default Re: Dry nitrous kit and p28 ecu open loop
i might be wrong but kenjis program puts timing in to it, for nitrous u will have to pull timing out. so only problem i see would be timing issues
Old Nov 12, 2004 | 10:40 AM
zcnitroso's Avatar
Suggestion, go with the wet, dry kit SUCKS...
I miss tampa fl
Old Nov 12, 2004 | 12:22 PM
terry.ho's Avatar
I love to choke people.
Wire in a MSD timing controller to your Crane Hi6. I have a ton of mods like you and spray a 75shot wet a lot with no problems. I used to run a 75shot dry though.
Originally Posted by fresh&clean
This is the worst place to get any advice at all.
http://www.myspace.com/terry_ho
