type r in eg.....brakes
Old Sep 17, 2004 | 06:00 AM
4dorteg's Avatar
Allan works as well
Default type r in eg.....brakes
would a type r brake booster and master cylinder work in an eg w/out abs? i know the rs teg will just curious if the type r would.
i dont want to have to redo brake lines or anything just a bolt on upgrade.
Old Sep 17, 2004 | 07:09 AM
4dorteg's Avatar
Allan works as well
all gsr all the way around, the reason i am asking is because i MAY
be able to get the type r for the same as the gsr $ wise and i would believe the 1" m/c would be better than the 15/16". it may just be an option
TR salesman..........
Old Sep 17, 2004 | 07:27 AM
Bill's Avatar
Livin' in Seattle
That's what I run in the civic. Type-r booster and MC. No issues.
Old Sep 17, 2004 | 07:36 AM
4dorteg's Avatar
Allan works as well
thanks............also should i run a type r prop valve or 99-00 si
Old Sep 17, 2004 | 09:09 AM
Bill's Avatar
Livin' in Seattle
You'd only run a 99-00 Si prop valve with a 6th gen civic due to ease of install and lack of ABS. For your app you're going to need to source a teg prop valve without ABS, something like the RS model.
Old Sep 17, 2004 | 09:12 AM
4dorteg's Avatar
Allan works as well
thanks for the info...........
