question about turbo kits for b16
Old Aug 28, 2004 | 02:34 PM
nightwolf2369's Avatar
Default question about turbo kits for b16
i have been looking up turbo kits for the b16a1 that i got in my 91 teg. anyways i have been seeing many different kits. i know that the intercooler piping will not be the same if i buy a kit for the b16 since it is meant to be in a civic or will it. anyways, i know must of u will tell me to piece together my own kit. will u plz list all the parts i would need to custom make my kit and where would be a good place to take it to.
Old Aug 28, 2004 | 11:42 PM
CiViCBoY's Avatar
Lamer
order the turbo you want a manifold for B motor and intercooler pipes for your model car
Old Aug 29, 2004 | 09:53 AM
juiced2ndgenteg's Avatar
TURBO on DA chassis(90-93 teg) is NOT easy! the front crossmember SUCKS! it leaves you NO room. If you use a small turbo(14b, t25) you might be able to fit it with the stock crossmember. but if your planning on running a t3/t4 with a equal length manifold it will NOT fit easily. the only company that makes kits for gen2 tegs is revhard...i think... I just puchased a z10 crossmember and traction bar setup for my TEG to make life easier. It makes sooooo much more room under there. I have fit a 16g(eclipse upgrade) with a SFP manifold on friends completely stock gen2 teg(b18a) without A/C but with the stock crossmember. it ran 14.6 on 6psi and 15.5 on 4 psi(using the SAFC hack)... 10 psi shoulda ran mid 13's untuned... even with a NON-driver behind the wheel...
Old Aug 29, 2004 | 10:36 AM
where can i buy these z10 crossmember bars at? anyways so buying a kit for the b18 would still work with the jdm b16 in the car? if so then that makes things a hell of a lot easier. anyone else care to help out on what i should do
Old Aug 30, 2004 | 01:16 PM
they're a bit pricey at $450+options... www.z10eng.com. buying a turbo kit is easier to install but a bit more $$$$ than piecing it together.
