Dumb Header Bolt
Old Aug 7, 2004 | 07:17 PM
TRD_Tc's Avatar
Using The Force Of N/A
Default Dumb Header Bolt
Well just my luck I let one of my friends help me out with my car and he screws up. He cross threaded one of the bolts that holds on my DC Sports Header. As if things couldn't get worse they did. Instead of him bringing the whole thing to my attention he just tried to take it back out and the head of the bolt snapped off. Now how the hell am I supposed to get the Stud part of the bolt out of my head? Anyone with advise please post up. I have a feeling this is going to be a pain in the ass.
Old Aug 7, 2004 | 07:42 PM
japanbran's Avatar
Bo0st FTMFW
you could try to get a drill tap and tap that stud... then try to pull it out with another bolt in it????
phearable.net
R.I.P DJSTANG. YOU WILL NOT BE FORGOTTEN!!!!
Old Aug 7, 2004 | 07:49 PM
kender's Avatar
gadget man
a drill and an ez out, you drill a hole in the end of the stud that is smaller than the threads of the ez out, then you screw in the ez out ( it is reverse threaded ) so when it starts to tighten down it is turning the stud counterclockwise. once the stud is out the final step is to give you friend a head stud suppository
U.S.S.A Crew Member #001
Old Aug 7, 2004 | 09:29 PM
japanbran's Avatar
Bo0st FTMFW
^ good idea... i forgot about an ez out
phearable.net
Old Aug 8, 2004 | 01:41 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
Is any of the stud sticking out??? If it is I would just double nut it....
And why does this sound like something David would do???
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Aug 8, 2004 | 04:51 AM
TRD_Tc's Avatar
Well Chris....you nailed who it was on the 1st try. lol. No, non of the stud is really sticking out far enough for me to really get a hold of. Where could I get an EZ Out?
Old Aug 8, 2004 | 08:31 AM
lsrex212's Avatar
discount has a cheap set if u dont want to spend much...but sears or even home depot might have better ones...the discount ones are not that good but should still work...
Old Aug 8, 2004 | 06:31 PM
TRD_Tc's Avatar
Funny...I work at Home Depot so I'll check there tommorrow. If that doesn't work then I might have to take the drilling route...thanks fellas.
Old Aug 8, 2004 | 06:34 PM
koopa's Avatar
The tenth little indian
use an easyout or an extractor bit. i had to go the same route when a buddy of mine over torqued one of my valve cover bolts on my del sol :shutters: , just be really careful with it so you don't have it messed up anymore...
