Fuel problem
Old Jul 19, 2004 | 04:20 PM
40ozCasualty's Avatar
shift_lock
Red face Fuel problem
Alright, I sold my car to a guy, and he calls me today and says that it won't start. So I go to help him assess the problem. First thing I think of is that the Main relay is bad, So I brought the other one out of my car pluged it in, and still nothing. Meanwhile its giving me a CEL, but WILL NOT display any error codes. If i press on the main relay to engage it manualy, The CEL light blinks really fast, the relay fights me, and the ECU light blinks with the CEL light. So since I can't read the codes, and I can't hear the fuel pump turn on, We try to hardwire the fuel pump, Do it and the fuel pump turns on, Keep it hardwired, and try to start the car, Fuel injectors aren't firing. Does anybody have some insight?
Old Jul 19, 2004 | 04:21 PM
shift_lock
oh by the way, used some starting fluid, and it starts right up and dies. So its getting spark.
Old Jul 19, 2004 | 05:04 PM
shift_lock
Old Jul 19, 2004 | 06:58 PM
cxcivic's Avatar
swapin' Hondas since '95
what kind/year of car?
K20turbo EG hatch 10.49@136
street tuned by NS RACING
??check engine light?? Tranny grinds??I fix'em!!
I MAKE HOUSE CALLS!!
SAME DAY ECU CHIPPING
I <3 WIRES
NS RACING (813)842-5517
chipped P28's $125
http://www.youtube.com/watch?v=nbsSp...a_player<br />
http://www.youtube.com/watch?v=koGfpMAvfWk
http://www.facebook.com/neal.sutton.750
Old Jul 19, 2004 | 07:06 PM
shift_lock
Doh, I knew I forgot something. Its a 90' CRX DX
Old Jul 19, 2004 | 07:30 PM
SEEKERone's Avatar
Trialed for Treason
i had similar problem (relay buzzing and CEL flashing) that was caused by the ground wire at the thermostat housing being loose.
Liar, you couldn't cut me deeper with a knife if you tried
Old Jul 20, 2004 | 12:28 PM
shift_lock
Hmm, I have to double check all the grounds, I did a once over on them, But didn't really check them.
Old Jul 20, 2004 | 03:52 PM
zasa214's Avatar
wow that sounds weird. trying not to point out the obvious but it seems like its gotta be something with the ecu maybe it jus took a shit on him never know i havent seen it happen but then againn i havent seen alot of things. good luck
Old Jul 20, 2004 | 06:28 PM
shift_lock
I don't know, Im guessing it has to be the ECU, or mabye a ground. Someone also said that the Alternator fuse, could do this? The main relay from my car works in my car, and the main relay in the car I sold him worked before I sold it to him, and it doesn't do shit with either.
