B18 Block
Old Jun 19, 2004 | 07:04 PM
93SiRhatch's Avatar
Default B18 Block
i've got a 93 hatch with an SiR. i'm thinking about swapping a GSR block. having troubles locating one, but admittedly haven't looked very hard. anyone know of one for sale?? also, if i used an LS block would it be worth it...could i use my internals with LS block?
Old Jun 19, 2004 | 07:07 PM
na200whp's Avatar
Powered by BOOST
you could use the pistons in the ls block w/ some apr rod bolts and that will give you a solid block. id recomed new bearings and you will need new rings.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Jun 19, 2004 | 07:08 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
First, this isn't the Want To Buy Forum. That being said, you CAN use your internals, your pistons on LS rods and an LS crank would yeild about a 12.6ish:1 CR if i'm not mistaken, if you put your head on it (and did some other things that you can find for yourself while searching) you would have an LS/Vtec making some pretty sick power.
Old Jun 19, 2004 | 08:10 PM
mtber's Avatar
p30 pistons in a ls block using a b16 head yeilds 11.6:1-11.8:1 c/r
Old Jun 19, 2004 | 08:13 PM
I hate you. Yea, i DID say "if i'm not mistaken". But i looked it up and you are right as fucking always. Once again, i hate you.
Old Jun 19, 2004 | 08:34 PM
mtber's Avatar
