FueL problem!@!!! heLPppP
Old Jun 14, 2004 | 07:45 AM
taydohustler's Avatar
Default FueL problem!@!!! heLPppP
hey i have a LS motor in a 96 ek hatch..........everything is done ...only thing is........when we turn on the car.......its not gettin n e fuel.........we checked the fuse.......and the fuel pump......but theres no fuel coming out.........can someone please help??????? thanks!!!!!!!!!!!!!
Old Jun 14, 2004 | 08:19 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
if the fuel pump isnt coming on and the fuse is good, its either a wiring problem, a bad relay, or just a bad fuel pump....
Call me up and I'll try to come check it out this week as soon as my car is running.....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Jun 14, 2004 | 09:09 AM
lowoctane's Avatar
Professional Dumbass
what about the fuel filter?...i remember i wasnt getting any fuel and it would start and then bog out, sometims wouldnt even start, then after i changed that, it all went away, its only like 13 bucs.
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
Old Jun 17, 2004 | 07:19 PM
mtber's Avatar
Make sure your "green plug" is plugged into your harness.
This plug is located next to your ecu plug.
Turn your ignition on (double click) listen for a noise (fuel pump) if you hear it then you obviously got a fuel delivery issue.
Good Luck.
Old Jun 18, 2004 | 09:49 AM
Default thanks
hey thanks for the tips.........i just remembered.......the wiring harness that i got was from my coupe..........i had turbo before.......so theres another plug that comes out from my harness ........could it be that i have to plug in the greddy blue box.......in order for the fuel to work?
Old Jun 22, 2004 | 07:19 AM
Default help!!
n e one in the land o lakes area? that can come out help me look at this problem? please let me know thanks!
