oil leak
Old May 14, 2004 | 04:29 PM
ninja999's Avatar
assassin
Default oil leak
i have a b16 and it is leaking oil from the motor and i cant find out where its coming from ive changed the oil pan gasket, distributer o ring, vtec solenoid gasket, but it is now leaking from the back of the block. does anyone know what it could be??? im putting a quart every three days. if anyone can help thanks
Old May 14, 2004 | 04:55 PM
TSX24L's Avatar
oil sending unit
Old May 14, 2004 | 05:00 PM
ninja999's Avatar
assassin
checked that already was ok
Old May 14, 2004 | 05:05 PM
TSX24L's Avatar
clean the engine down real wheel enough to remove the oil and let the engine run or go for a test drive and pull it back in the garage and see where its coming from. I would make sure then that your oil filter is tight. Where at in the "back" or the block does it appear to be runing down from?
Old May 14, 2004 | 05:09 PM
ninja999's Avatar
assassin
thats the thing ! i cant see where it is ive had it on the lift and i cant see where its coming from. im going to clean it up real good in the morning and hopefully i will find it
