Car boggs at 5k rpm
Old May 13, 2004 | 08:04 PM
HondaCRX's Avatar
Vtec what?
Default Car boggs at 5k rpm
94 civic ex with d15 block and jdm 1.6 vtec head
Driving on 275 and was in 4th gear and about 4.5k rpm and it started to bogg and will not go over 5k rpm. Stoped at the store and checked my oil (oil is fine) So get home and check the dizzy and all wires everything checks out ok. Also when i start the car up it goes over 5k then about two mins of running it wont go over 5k again. So what could be doing this.
any help would be greatfull
Old May 14, 2004 | 12:33 AM
HondaCRX's Avatar
Vtec what?
ttt any one ?
Aim: Hondacrxls
Old May 14, 2004 | 04:15 AM
40ozCasualty's Avatar
shift_lock
I'll add somemore about what its doing. Once he gets it to about 4.5k rev It starts jumping around real bad, Almost like a funky cracked out rev limiter, But it also sounds like its misfiring while its doing this.
Old May 14, 2004 | 02:53 PM
U13SER's Avatar
Could Be Running Lean!
Old May 14, 2004 | 06:31 PM
HondaCRX's Avatar
Vtec what?
going to work on it some tonight
Aim: Hondacrxls
Old May 15, 2004 | 05:37 PM
HondaCRX's Avatar
Vtec what?
top
Aim: Hondacrxls
Old May 16, 2004 | 05:40 PM
HondaCRX's Avatar
Vtec what?
check the dizzy and all the wires and stuff all looks good
could it be the ecu? or the vtec not working right? I was running the car for a few days with no vtec working. thanks
Aim: Hondacrxls
Old May 17, 2004 | 01:24 AM
crix's Avatar
:mugen member:
hook up the vtec/oilpress.. 2 the ecu
check engine lights ?
also check the rotor...
Old May 17, 2004 | 11:16 PM
HondaCRX's Avatar
Vtec what?
ok the vtec and oilpress are hooked up
have diffents ecu codes 7, 14, 21, 22, 41
what about the rotor?
Aim: Hondacrxls
