Harness q.
Old May 9, 2004 | 09:28 AM
TSX24L's Avatar
Default Harness q.
What harness am i going to use to when chaning in a b18b1 swap into a 91 hf crx? Mine or the ls .
Old May 9, 2004 | 10:22 AM
crix's Avatar
:mugen member:
if you use the HF harness on the motor,then you will only need the ecuPR4,Dizzy,injectors,& map sensor..
OBD-1 then U need a converstion harness for the ecu ,then a list full of wiring..
Old May 9, 2004 | 10:28 AM
TSX24L's Avatar
How will my ls dizzy hook up to the hf harness?
Old May 9, 2004 | 11:36 AM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
if it is obd0 then its good...and plus hf is wired multi port n e way....
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old May 9, 2004 | 12:54 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
You will need to replace some stuff on the B1 to run the crx harness..... what year is the motor? Is it obdI or obdII????
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old May 9, 2004 | 01:23 PM
TSX24L's Avatar
obd1
Old May 9, 2004 | 01:40 PM
Retired Ricer...
i think youll just need a non obd distributor or someone to rewire yours to make it work, youll need an obd-0 LS alternator, and you have to rewire the injector clips... I cant think of anything else right off top... Honestly, Id just convert it to OBDI to make it easier
Old May 9, 2004 | 02:45 PM
crix's Avatar
:mugen member:
you can rig the HF dizzy for temperary intill u get the right 1
this way it will plug in/work ...
