Idles fine but stalls when coming to a stop, Having to pop start all the time
Old Apr 27, 2004 | 12:23 PM
Outkasted24's Avatar
** I ♥ Old Skool **
Default Idles fine but stalls when coming to a stop, Having to pop start all the time
OK, This is hopefully the last tech question I'll have to ask for a while since I've replaced just about everything under the hood lately. Hehe J/P
I just replaced my Igniter, Dizzy rotor and cap, spark plugs, created extra grounds, and did an oil change since last Friday when my car died.
Now, When I'm coming up to a stop , Sometimes the car will keep running but more then likely it'll stall.
While coasting to a stop, I can pop start it and then it will run fine again.
This has happened more then 25 times since the car returned back on the road Monday evening.....It's only tuesday afternoon now
What could possibly be the problem now?
Any suggestions befor I drive this damn thing over a cliff or into the Hillsborough river?
It's so Embarrassing having to pop the clutch at every stop light
My Flickr
slam.poke.drop.tuck.dope
Old Apr 27, 2004 | 12:31 PM
ONEBADWANKEL's Avatar
Try swapping your computer. Thats one of the first things I would check with those symptoms. And check your grounds again.
Old Apr 27, 2004 | 12:49 PM
** I ♥ Old Skool **
can't swap the comp., I'm running Hondata and this one is chipped
Next.
My Flickr
Old Apr 27, 2004 | 02:25 PM
99B16Si's Avatar
that used to happen to me when i first installed the aem ems in my car. i had to mess with a few idle settings inside the program and it hasnt happened since. im sure hondata is a bit different tho but im sure theres many adjustments for idle control
Old Apr 28, 2004 | 02:22 AM
** I ♥ Old Skool **
Originally posted by Vapor
. Are you still pulling the same vaccum as before?
Yes, Exactially the same.
Keith, Hook a brother up then. Heh
If I replaced all these goodies, Then the next day it starts stalling...Don't you think it would be something I installed or did wrong to make this problem occur?
Is there a way I can clean (safely!) the sensors, some kind of induction or carb cleaner?
My Flickr
Old Apr 28, 2004 | 06:49 AM
99B16Si's Avatar
brake parts cleaner for the iacv screen
Old Apr 28, 2004 | 08:26 AM
juiced2ndgenteg's Avatar
check your fuel pump. my old ass supra used to do the same thing for like 2 months. then the fuel pump finally went. IAC needs to be checked also.
