92 accord wont start when hot outside
Old Apr 11, 2004 | 11:15 PM
98TRDCam's Avatar
iron lung
Default 92 accord wont start when hot outside
my 92 accord ex wont start when it gets hot outside. already replaced the coil,cap,rotor,dizzy,wires,plugs,etc. asked a couple of shops and they cant give me a real anwser. has anyone else had this problem and if so how did you fix it any help is much appericated.
Old Apr 12, 2004 | 02:12 AM
crix's Avatar
:mugen member:
I know the problem & seen it a lot of times
it may be the relay ?
LMK IF U Need help!........
Old Apr 12, 2004 | 07:46 AM
24-7's Avatar
Civic Racing eXperiment
Default Re: 92 accord wont start when hot outside
Sounds like a V8 problem...check all the fuel system and make sure everything is clean and working correctly.
Old Apr 12, 2004 | 08:28 AM
sone's Avatar
main relay.....i could fix the relay if you don't want buy a new one......lmk...sone
Old Apr 12, 2004 | 09:10 AM
98TRDCam's Avatar
iron lung
already replaced the fuel filter, pump, and cleaned the injectors about 2 weeks ago.
the main relay is that the one under the dash or under the hood.
Old Apr 12, 2004 | 06:54 PM
SEEKERone's Avatar
Trialed for Treason
+1 main relay...seen this hundreds of times at work
main relay is under dash...on your 92 accord it is partially hidden above the cruise control unit
Liar, you couldn't cut me deeper with a knife if you tried
Old Apr 12, 2004 | 07:16 PM
98TRDCam's Avatar
iron lung
thanks everyone for your help im gonna try that and see
Old Apr 16, 2004 | 11:32 AM
pimpin's Avatar
pimpin
did it fix it
