cam gear
Old Apr 6, 2004 | 11:50 AM
NitrousAcid069's Avatar
4.6L Rice Eater
Default cam gear
is a cam gear on a d16y8 motor going to show any hp or tq. increase at all? ive heard yes and no about this, so im not sure....i got a brand new AEM cam gear for free from one of my friends....so no flaming me for wasting my money....also...how would one go about putting this little item on?
John
Old Apr 6, 2004 | 12:15 PM
SickOfAlltezzas's Avatar
ALUMINUM POLISHER
dont waste your money,dont buy jefros cuz 80-100 is alot
Originally Posted by 240Cyanide
TR's better anyways.. where else could you find all this variety of assholes, drug specialist, and pedo's? not on that gay dsm site!
Old Apr 6, 2004 | 12:17 PM
calloway 91si's Avatar
you should set your timing at top dead center and loosen the tensioner and then bull the belt off and take off the stock gear and replace it with the aem gear ....and for single cams i found that advancing it 2 degrees you get the best performance out of it but all motors are different so dont hold me to it
Old Apr 6, 2004 | 12:49 PM
4.6L Rice Eater
im not, im getting illianos from his del Sol
Old Apr 7, 2004 | 09:06 AM
ALUMINUM POLISHER
its not gonna be anything noticable.spend the money on somethin else
Old Apr 7, 2004 | 09:19 AM
pressuredsol's Avatar
Pleasure the do me
When you get your car tuned is when you will notice a difference with the cam gear.
Old Apr 7, 2004 | 09:44 AM
LS_ken-e's Avatar
A.D.D. for life
make sure you mark it at TDC, remove the timing belt. pull your valve cover and put a wrench on the cam. there will be a spot for you to fit the wrench on. and double check your cam timing and your crank pulley to make sure everything is lined up before you start adjusting.
LOOKING FOR 3rd Gen Integra windshield trim! HELP!!!!
not your typical honda driver...
AIM: kenracer18
Old Apr 7, 2004 | 07:28 PM
n20teg's Avatar
this is a ez way of doing it but it is a pain in the ass..for maken power your name says something about nitrous ,i dont know any thing about your set up but ,i was running a big shot of n2o and i wasnt maken any power, it was because of over lap my exaust side wasnt colsed long enough for my motor to fill up with nitrous ,so that mean is was gong out my exaust .i found that out messed with my cam gears i went for 230whp to a right at 300whpso it depends on your set up so i say yes get them
