2 and 3 step selector
Old Mar 16, 2004 | 11:04 AM
Old Renegade's Avatar
Cool Runnings
Default 2 and 3 step rpm selector
Got the basic concept of how to install a two step, it goes into your msd pill input ground it out then the red wire goes to a switch to switch between module 1 and 2. What got me stumped is the 3 step, cause in the instruction it was saying the need of a line lock or a trans lock. Is this really needed cause i figure this is for auto cars only. For the step 3 mod 1 will be activated by switch during burnout, so will mod 2 be activated by deactivating the switch or by clutch or by having the switch activated and clutch? and will mod 3 be activated when switch is on? cause 3 acts as your rev limiter, while 2 is for staging. Reason asking about the clutch is because in the diagram it was talking about clutch switch or msd micro switch. Now with a shift light will it be affected just as it is ,activation due to rpm selected on the tach, or will this have to be wiried in. when not using 1st and 2cd module , such as in regular street driving, the last pill should activate the shift light.
Thanks in advance.
Old Mar 18, 2004 | 07:17 AM
Cool Runnings
any info?
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Mar 21, 2004 | 10:48 AM
Cool Runnings
has no one out there used these ???
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old Mar 21, 2004 | 12:55 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
check out www.msdignition.com ... Itll tell you alot... You can wire one stage to a switch/button for the burnout, one to a microswitch on your clutch pedal for staging/launch, and the other as your normal limiter.....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Mar 21, 2004 | 01:16 PM
Cool Runnings
did do that and got some info but not clearly sure on the three step.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
