Need Help with RPM Activator switch to VTECH
Old Mar 16, 2004 | 07:56 AM
93_Del Sol's Avatar
Exclamation Need Help with RPM Activator switch to VTECH
Can anybody help me with hooking up RPM Activator switch to VTECH in a 96 hatch.
Old Mar 16, 2004 | 08:09 AM
mtber's Avatar
Don't ghetto the car that way :-/
Wire it to a vtec ecu the right way.
Old Mar 16, 2004 | 06:40 PM
NitrousAcid069's Avatar
4.6L Rice Eater
Originally posted by `92CXhatch
also "vtech" is a phone vtec is a process used to change timming in hondas...
-Keith
i think you got it right....to bad this information isnt available to some advertisers in autotrader...lol
Old Mar 16, 2004 | 09:18 PM
mtber's Avatar
If you need assistence wiring the vehicle result to wiring guides or professional assistence.
1st thing I reccommend you do is, get your hands on a ecu for that motor/vehicle that supports vtec i.e. 96 dohc gsr swap in a 96 civic uses a obd2a p72 ecu.
Next find a wiring guide:
http://www.phearable.net (In the tech section under katmans civic wiring guides)
Wire the motor up & call it a day
Make sure you take your time, use a sodering gun, heat shrinking wire insolator, & electrical tape.
Old Mar 17, 2004 | 12:30 PM
Janky99's Avatar
Honda Guru
If you have a summit RPM activated switch, pm me and ill scan the wiring diagrams -Ben
