engine codes
Old Feb 1, 2004 | 12:05 PM
91IntegVtec's Avatar
Default engine codes
my ecu threw a 6, then a 17... i know a 6 is crank angle, and that a 17 is the vehicle speed sensor, so what the hell is the crank angle????
Old Feb 1, 2004 | 12:59 PM
anyone know, please?
Old Feb 1, 2004 | 01:59 PM
Spyderxl98z24's Avatar
Honda Tech/ Local AssHole
crank angle signal tells the position of the crank in relative to the cams and timing ! DUHR lol It tells the comp what piston is up and which is down so you can fire on the right cylinders in squence with the dizzy and Valve openings. Its a computer thing lol If thats not working your obviously not running !
Old Feb 1, 2004 | 03:04 PM
mtber's Avatar
Code 6 is supposed to be
ECT Sensor (Engine Coolant Temperature)
defective circuit or unplugged / defective sensor
That is what I have in my notes.
Old Feb 4, 2004 | 02:13 PM
ok, thank you...could a bad o2 sensor cause a car to crank a few times before it fires?
Old Feb 4, 2004 | 02:14 PM
i mean before it starts up
Old Feb 5, 2004 | 04:01 AM
honda-tech's Avatar
Guest
who is this honda certified dumd ass any ways giving out shitty info
Old Feb 5, 2004 | 04:34 AM
IntegraL's Avatar
It is gone
no need for you to say shit like this... stfu
ibtl
2004 Blue Sapphire Sentra SE-R SpecV
