b16 wont work and dont know why
Old Dec 31, 2003 | 01:22 PM
88crxb16's Avatar
Default b16 wont work and dont know why
i put a b16 swap into my crx and i cant it to start or run it wont turn over. I have a voltage meter and i hooked it up to THE STARTER. i put it on the power wire from the harness and i put the other part of the voltage meter on the starter and i have no power going to the starter why. and if my sensor relay is fucking up is that why i am not getting power to the starter but i am getting power all over the car why why whyhelp i need my car
b16 on the way
Old Dec 31, 2003 | 06:09 PM
Sunrise City Rider's Avatar
WHAT!?! OK!......
CHeck your grounds...
I work too damn Hard...
04 Civic Si
01 Lexus GS300
Old Dec 31, 2003 | 08:07 PM
vertigo_16201's Avatar
its a common problem, dont worry. The b16 doesnt have enough torque to turn itself over.
Old Dec 31, 2003 | 08:36 PM
sickazz-92HATCH's Avatar
how much psi!!!!!!!!!!!
talk to kj @zmr
want a smoke and a pancake
Old Dec 31, 2003 | 09:19 PM
rangcrx's Avatar
engine building &best
im guessing then your crx was a Dx
i love AUTOZONE
Old Jan 1, 2004 | 01:33 PM
civicracer901's Avatar
B16ACRX
Is the fuse box hooked up along with the pos.battery cable and starter, all hoooked up? Is your starter grounded?
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Jan 2, 2004 | 06:55 PM
coleon's Avatar
RedNeck Refab.Inc
Check it out can you throw 12 v to your terminal going into starter, not the terminal on the solinoig. If you hook up a constand, engine acting as a gnd, it goes, solinoid issue, or a gnd. node on thermostat. JAT
And When It Rains.. It Pours..
Roughneck Refab .Inc
Old Jan 2, 2004 | 06:56 PM
coleon's Avatar
RedNeck Refab.Inc
you power all the wround, spark at plug, fuel pump kicks on, and the ecu's hot, then its not your main relay, its only 1 of 2 stupid thing that may have been overlook, nobody perfect
