Alignment questions?
Old Dec 5, 2003 | 02:04 PM
Spence's Avatar
"TEAM WHITEY"
Default Alignment questions?
Well i noticed my rear tires are wearing on the inside pretty quickly since they are pretty new so i took it to sears they put it on the machine to tell me what was wrong so here are the numbers tell me what i can do and who can do it for me as in alignment.
Front
Left camber-2.2
Right camber-2.3
Left toe -.81
Back
Left camber -1.3
Right camber -1.2
Toe left -.43
toe right-.70
The toe they said they could prob adjust cause i would need a toe extension is this true?
Thanks
Spencer
REPRESENTING PORTLAND OREGON THE WEST COAST TR MEMBER
Old Dec 5, 2003 | 02:50 PM
Bill's Avatar
Livin' in Seattle
That's a hell of a lot of toe, no wonder you're killing tires.
I run 0 toe in the rear and only like .35 toe out (-0.35) in the front. They should be able to zero out the rear and adjust the front (you'll probably want toe in for the front) without needing anything unless your arms are bent to holy hell.
Old Dec 5, 2003 | 02:53 PM
Spence's Avatar
"TEAM WHITEY"
Thanks Bill where should i go to get this done? And how much would washers on the back correct this problem?
Old Dec 5, 2003 | 04:47 PM
GOTTI's Avatar
OEM Parts Specialist
i put the washers on the rear of mine and it corrected it i also put longer bolts on the rear that go in the washers...just wanted to be safe...they were some honda bolts that fit from my bucket o' bolts.
Old Dec 5, 2003 | 05:31 PM
Josh's Avatar
Dr. Doom
firestone on 60. you can get free lifetime alignments for like 150 or something.
