how can i get more air
Old Nov 24, 2003 | 03:28 PM
evol_crx_si's Avatar
Aint Flakin
Question how can i get more air
I have my timing set to advanced alittte with a cam gear and distouber i havew fuel presurre regulator set to 28 psi and i have a front mount aire intake and i am running rich as all hell. at idle and when i lay into the gas but when i let off it go's to stouch but never lean at anytime..... does anyone have any idea how i can get more air or something to lean it out some.... and if turn down the presurre its all boggie thanks for anmy help i can get
Old Nov 24, 2003 | 04:50 PM
NChatch's Avatar
i stepped on my weiner!
seriously why would you want to see yourself go lean on any type of gauge????
i dont see the point
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Nov 26, 2003 | 05:28 AM
Aint Flakin
I"M looking to run stouch. I don't want to be mega rich... that means i'm losing power and not burning all the gases that i am dumping into the chambers. Would a Full MSD 6AL with cap and blaster coil help me burn at a less rich state?
Also does anyone know if it is common for single wire o2 sensors not to give a full cycle from lean to rich? thanks
Old Nov 26, 2003 | 07:00 AM
Derka's Avatar
TR Balla Donor Supreme
I woudnt trust that gauge, its basicly a light show... If anything get an egt gauge or goto a dyno n get a wide band hooked up
1998 crv daily beater
Old Nov 26, 2003 | 08:07 AM
ComatoseSedan's Avatar
Fo Shizzle My Nizzle
factory Honda ignition is more then adequate for anthing allmotor, you need to get it tested with wide band o2 monitoring
'88 Civic Sedan - Cardinal Metalic Red
153.5 whp AllMotor
www.LHTperformance.net
Old Nov 26, 2003 | 08:12 AM
Alpha's Avatar
ComatoseSedan is right. Invest in a VAFC and some dyno time with a wideband.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Nov 30, 2003 | 04:06 PM
F4A22's Avatar
Old School
If u run premium i suggest advance ur timing a bit more and check ur plugs.
Old Dec 1, 2003 | 12:46 PM
Aint Flakin
thanks for all the input guys
Old Dec 2, 2003 | 07:46 AM
StricKlyMT's Avatar
aka civicke96
i've also found that that gauge is just a light show id say invest in a vafc also and go to the dyno
"STRICKLY MT" Shop open for business
Tuning available for S300 and Kpro
727-510-6301 Tristan
11.99@116 All Motor K24 Civic Eg6 on Drag Radials
MattBuilt
