Idle Problem
Old Oct 30, 2003 | 07:59 AM
94DOHCDELSOL's Avatar
TR Balla Donor Supreme
Default Idle Problem
When I am at a light, my idle goes from 1.5-2, just keeps on moving inbetween 1.5-2, just wondering how to fix this...???
Old Oct 30, 2003 | 08:14 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
make sure all ur senors are plugged in.
i had this problem about a weekago
tamparacing.com
Old Oct 30, 2003 | 10:36 AM
mtber's Avatar
Check you're car for a CEL (Check Engine Light).
If you have one check you're Trouble Codes.
If you are not throwing a code:
a. You're Idle Air Control Valve on the back of you're intake manifold is bad/dirty.
b. You're throttle body has a fast idle thermo valve & it needs to be overhauled.
c. You have a vacume leak somewhere.
Good Luck.
Old Oct 30, 2003 | 12:47 PM
Vito_Corleone's Avatar
PCV valve, throttle position sensor, or random vacuum leak.
Old Nov 4, 2003 | 08:53 PM
thanks
