VAFC and b&m fpr question
Old Sep 15, 2003 | 04:29 AM
Vtec4theChildren's Avatar
no the AFC can not tell you Fuel Pressure
you need to get a gauge for it 10-20 bucks
get the one that mounts on the fuel filter service port
Old Sep 15, 2003 | 04:46 AM
F4A22's Avatar
Old School
Better fuel readings are given if the gauge is mounted on the fuel rail not the filter.
Old Sep 15, 2003 | 04:58 AM
if you have a place to mount it on the rail make sure you get a liquid filled gauge then...the non filled one have a tendency to malfunction because of engine vibrations
how would it be more accurate? if youre seeing pressure drops in the fuel pressure because the guage is mounted somewhere else then you have other problems not the gauges
Old Sep 15, 2003 | 05:25 AM
if your car is running temendously lean then it would seem that the FPR is not the solution but rather a higher volume fuel pump is need and now with the FPR you can bring the pressure down to more normal pressure levels
AFC is also an excellent suggestion by cronic espcially if you want to fine tune the A/F curve
and Dyno time is always a must for tuning
contact SS
