b18c1 into 97 dx
Old Aug 26, 2003 | 03:42 PM
hockeyfreak007's Avatar
The Deliverer
Default b18c1 into 97 dx
exactly what mounts do i need to buy? i need year and car they come off off.....the gsr is still in the gsr so we have all of those mounts. let me know
thanx
parker
Old Aug 27, 2003 | 04:23 AM
KJ's Avatar
KJ
bored at work
Driver side:
-you need a 99-00 civic si bracket (bolts to block)
-you reuse the stock civic liquid filled mount and skirt
Rear Tranny:
-you use the stock chassis mount that bolts to the rear crossmember
-you use the 99-00 si rear tranny bracket
Upper tranny:
-Use all the stock mount pieces
Front tranny:
-Use the gsr bracket
-You can use the stock civic chassis mount or the gsr's, I believe the gsr is a little beefier
A/C mount:
-you need a 96 Del Sol Vtec a/c bracket (P54) to retain a/c
-use the stock chassis mount
-if you buy the bracket from Honda it will come bare, use the pulley and lever arm off the gsr bracket
Old Aug 27, 2003 | 11:19 PM
Crab Cakes's Avatar
So Lost!
Default Re: b18c1 into 97 dx
thanx
parker
I will be doing that swap soon....
Im The Original Crab!
Old Aug 28, 2003 | 02:20 PM
mtber's Avatar
have fun wiring the dx harness...
vtec:
a8 vtec cylinoid
c15 vtec pressure switch
d6 knock sensor
gsr intake butterflys:
a26 for IAB
Idle air control (change plug from 3 plug on dx harness to 2 plug)
a14 to a12 for iacv
Old Aug 28, 2003 | 02:46 PM
The Deliverer
since we have to rewire the gsr we're using the vtec harness that came with my ex since i put a ls swap in my ex. just mounts area problem
BImmer sold
Integra SOLD
http://hitemptech.com/ - HiTemp Technology Corporation – Specialists in high temperature (hi-temp) technology, non-burning technology, fume incineration and custom processing furnaces.
