Reminder: Hondata DOES do nitrous control
Guest
Posts: n/a
Source: http://www.hondata.com/featuresnitrous.html
Just wanted to throw this out there, since everyone seems to be so pussy about using NAWZ. Fuck that, get Hondata, and spray the FUCK outa your motor.
PS nitrous doesn't LOVE high compression, but nitrous also isn't afraid of it like some of you wussies are.
Forged internals make things much easier.
Important
Read the warnings at the end of this page.
What is Nitrous Control?
Nitrous Control is a feature of the s100 & s200 systems where the ECU control the use of Nitrous Oxide in the engine. A dry Nitrous setup is be used (where the fuel is supplied by the ECU), with the ECU switching the Nitrous solenoid on via an output pin from the ECU. Another pin input to the ECU is used to arm the system.
How does it work?
The ECU will ground an output pin to open a Nitrous control solenoid when a number of conditions are met:
* Nitrous system is armed.
* Engine speed is above a minimum setting.
* Throttle position is above a minimum setting.
* Vehicle speed is above a minimum setting.
At the same time the ECU switches the Nitrous on, it will supply an additional amount of fuel to the injectors, and optionally retard the ignition timing.
RomEditor Settings - Arming Input
This selects the ECU input which is used to arm the Nitrous system. The input needs to be switched to ground to arm the system. Two input pins can be used, but note that the A/C switch will need to re-wired from stock in order to work.
RomEditor Settings - Output Control
This selects the ECU output used to control the Nitrous solenoid. Use a relay between the ECU output pin and the Nitrous solenoid. Note that the ECU will ground the output pin to switch the Nitrous on, so wire the relay accordingly.
RomEditor Settings - Conditions
These set the minimum conditions before the ECU will switch the Nitrous on. As a rule only use Nitrous at almost full throttle and above 3000 rpm, depending on the size of the shot. The minimum vehicle speed can be used to limit wheel spin in the lower gears.
RomEditor Settings - Fuel & Ignition
This sets the amount of extra fuel to inject and the amount of ignition retard when using Nitrous. For a starting point for the fuel enrichment value take the value from the fuel table at peak engine hp e.g. if the engine makes 200 hp at 8000 rpm, and the fuel value at 8000 rpm and zero vacuum is 800, then you will need to enter a fuel enrichment value value of 100 for a 25 shot, 160 for a 40 shot etc. This is only a starting point - dyno testing with a wide band lambda meter is the best way of determining the correct values.
Nitrous Switch Wiring Diagram
Warnings
Exercise caution when using Nitrous. Make sure that:
* The fuel injectors have enough capacity to meet the fuel demands when nitrous is used.
* To use a relay between the ECU and nitrous solenoid.
* The minimum engine rpm and throttle position are sufficient so that the engine does not backfire when the Nitrous is switched on.
* If you start laughing uncontrollably, immediately switch the system off, stop the car and go to the nearest rave.
Copyright © 2002 Hondata, Inc. All rights reserved.
Products are for off road use. Warranty Information
Important
How does it work?
Warnings
Hondata nitrous controls and forged internals = the 125 shot John at Secret Services will be tuning my car for on Sept 13th.
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
Boost will be coming soon as well, but I am definately keeping the nitrous, just going to back it off to a smaller shot.
I've seriously thought about nitrous on my car, but I figure it would be pretty much worthless as the car will be a dedicated autocross car and not a street racer. The SCCA wouldn't like or allow running some squeeze on the autocross course.
