Skunk2 Intake Manifold
Old Aug 6, 2003 | 10:01 AM
mike34655's Avatar
Member
Default Skunk2 Intake Manifold
I am trying to mount my skunk2 intake manifold on my GSR. Everything is in place. The only thing I dont get is how the lower and upper Type R PCV hoses will be used to reconnect the breather chamber to the PCV valve, to the T-fitting opposite of the EVAP hose. Can anyone help me out on this question? Thats the last thing I have to do (Well except to install the fuel rail, but thats easy). Thanks for any info you could give.
Old Aug 6, 2003 | 11:29 AM
letsrollagn's Avatar
BRT OVERKILL
here is a diagram of stock...just run it from the breather box through the pcv and to the open air(run a hose down behind the manifold to keep everything clean) and plug the vac port on the manifold....unless you mean the vacuum tank and not the breather...which ecu are you using? If your running a p28 you can eliminate a great deal of the vacuum mess, I usually run the breather as stated and eliminate the vacuum tank, secondary butterflies, and egr...and just leave the fpr going to the manifold and plug the evap....if you have any more questions let me know, I could always come take a look and tell you what you need to do...
Why is it when ever I really need to weld something the acetylene always seems to run out...
Only babies drink from bottles...
Boosted 00 Si
N/A 93 HB b16/18
BRT OVERKILL
give me a call and I will explain if needed...I pm'd you my #
Boosted 00 Si
N/A 93 HB b16/18
