FS: 94-01 New Front bumper,B-Series: injectors, distributor, water/oil pumps + MORE!!
Old Apr 16, 2009 | 05:22 PM
95dc2teg's Avatar
Thumbs up FS: 94-01 New Front bumper,B-Series: injectors, distributor, water/oil pumps + MORE!!
First of I am located in Venice, which is about an hour south of tampa off I75. You can reach me through pm or can call me at 941-468-3467, the name is Anthony.
Full stock gsr valves/springs/retainers. Good condition, no bent vavles, retainers need to be cleaned up they have some surface rust forming.
2000 Integra GSR LMA's (Lost Motion Assemblies) great condition $75 for all 8. (these are expensive little fuckers from the dealer about $30 a piece)
-4an 3ft turbo feed line $10
Stock OEM 2000 GSR Cd Player (dont have code)$30
Stock 2000 OBD2B GSR Ecu $50
8" Slim fan $20
Type R outer tranny case ONLY. $40
OBD2 stock Gsr Injectors $25
OBD1 Stock GSR Injectors $30
Stock GSR Fuel Pump $30
has a broken crank pulley bolt inside, and also the keyway is fucked. $20obo
Brand new ABS Plastic 94-97 front bumper cover (no lip), has a scuff, but no big deal if going to be painted anyways. $80
stock fan clip cut off $10
stock ac fan w/ clip cut off $10
stock fan w/clip still attached $15
94-01 torque mounts filled. $15
94-97 stock corner lights $10
98-01 clear corner lights $10
stock gsr TB w/tps $40
stock honda horn $5
stock gas cap $3
Rockford Fosgate 10" "Punch" Subwoofers w/box 250watt/each $100
Stock GSR Flywheel (needs to be resurfaced) $25
Stock gsr IM - $10
stock gsr air intake shit from fender to bottom of car $10
short ram intake pipe with a threaded port for nitrous?? $10
spoot cat. not sure what its for, but i think its for an accord. $25
RESISTOR BOX - $10 (only one left)
OBD1 INJECTOR CLIPS - $7
GSR OIL PAN TAPPED BUT DENTED WHERE IT CONNECTS TO THE BLOCK - $35
OEM GSR RADIATOR UNKNOWN CONDITION LOOKS GOOD THOUGH - $30
OIL PUMPS - $10 each (not sure of condition of all)
WATER PUMPS - $10 each
PISTONS/RODS FOR GSR - $10
OIL PICK UP FOR GSR - $5
OBD2 CRANK POSITION SENSORS - $5
REAR MAIN SEAL - $10
OBD2 TIMING BELT GEAR - $10
#32!!
**If you are apart of the DC Crew and would like a DC crew Sticker shared_pm me!!**
Old Apr 16, 2009 | 05:36 PM
FC_V8's Avatar
bump for good stuff. i might need the fuel pump from you. ill let you know.
Old Apr 16, 2009 | 06:21 PM
95dc2teg's Avatar
alright buddy let me know!
#32!!
Old Apr 16, 2009 | 07:31 PM
jboyzTeg's Avatar
ttt .....
Old Apr 16, 2009 | 09:54 PM
95dc2teg's Avatar
thanks man ttt!
#32!!
Old Apr 17, 2009 | 06:35 AM
95dc2teg's Avatar
#32!!
Old Apr 17, 2009 | 11:30 AM
95dc2teg's Avatar
#32!!
Old Apr 17, 2009 | 11:13 PM
95dc2teg's Avatar
#32!!
Old Apr 18, 2009 | 09:26 AM
95dc2teg's Avatar
#32!!
Old Apr 18, 2009 | 03:31 PM
95dc2teg's Avatar
distributor sold!
#32!!
