Guns & Ammo Guns, Ammo, Knives, Weapons.. etc..
Laser sights
Old Jan 5, 2018 | 05:48 AM
Default Laser sights
It’s true.
There’s a special military grade technology that highly trained special operations teams and elite law enforcement personnel like SWAT rely on when they need INSTANT “from the hip” accuracy.
It not only works in highly stressful “life or death” close quarters combat situations to lock on to targets LIGHTNING fast…
It’s also their “unfair advantage” when spec ops soldiers and SWAT police need to hit targets at a distance. Targets that would be IMPOSSIBLE to hit with fixed sights.
And finally… this technology is now available to the civilian market… so you can start using it today to…
[h=1]Humiliate All Your Shooting Buddies At The Range![/h] This military grade targeting system works so well… and works so FAST… you’ll wonder why you ever went shooting without it!
It’s as simple as this:
[h=4]Mount it on your gun – any gun[/h] Pistol, rifle, even BB guns and paintball guns (it’s easy and takes less than 3 minutes)
[h=4]Turn it on… and…[/h]
[h=4]Start placing SUPER accurate shots…[/h] With groupings so tight it almost looks like you’re placing shots through the same hole!
[h=4]Once you get your hands on this targeting device… THAT is how easy it is to experience “spec ops” accuracy… without any additional training![/h]
Switch between 4 reticles!
Even if your vision isn’t like it used to be in your younger years, you’ll still be almost “computer precise” accurate… with ANY gun.
That’s why many of our customers say that it feels almost as if this thing aims your gun FOR you.
And now you can experience for yourself the thrill of placing every single shot EXACTLY where you want it. Up close or at a distance… it doesn’t matter. It works just as well either way.
Old Jan 5, 2018 | 05:49 AM
[h=1]This High Tech Military Targeting System
Aims Your Gun For You![/h] [h=3]Even if your vision isn’t what it used to be… this high tech piece of gear can DOUBLE your accuracy… almost IMMEDIATELY![/h]
[h=4]Now available to the public at the lowest price EVER![/h]
[h=4]Works with any kind of firearm[/h] Handguns, rifles, shotguns… even BB guns, paintball guns, and airsoft pistols and rifles
[h=4]Works in broad daylight and low light conditions[/h]
[h=4]Aquire targets lightning fast… even from the hip![/h]
[h=4]If you can see it, you can hit it…with darn near PERFECT accuracy![/h]
[h=4]Easy to attach to any firearm![/h]
Old Jan 5, 2018 | 05:50 AM
Even better…
[h=1]It Works In BOTH Low Light Conditions And In Broad Daylight![/h] In no time at all you’ll be nailing targets like a “dead eye” pro. While all your buddies stare at your target in amazement… wondering how you made such a fast transformation in your shooting abilities.
You’ll love how confident you feel once you know you can hit targets with laser-like accuracy… consistently, reliably and predictably. Regardless of distance, lighting conditions and your current shooting ability.
Old Jan 5, 2018 | 05:51 AM
[h=3]Once you’ve mounted this bad boy on your gun…[/h] [h=1]It’s Almost Impossible To Miss Your Shot![/h]
That’s why our armed forces use this technology day in and day out to defeat enemies throughout the world.
And for a VERY limited time, YOU can get one of these military targeting devices, too.
After months of searching, we’ve just gotten our hands on a limited supply of these military grade, high tech targeting systems.
[h=3]And while supplies last, we’re offering you the opportunity to try one…[/h] [h=1]At The Lowest Price We’ve Ever Offered![/h] Here’s what it’s all about:
We’ve just introduced the “MCG Reflex Red Dot Sight.”
It’s THE find of a lifetime for gun owners who want INSTANT ACCURACY… without any additional training.
[h=3]Just mount it on your pistol or rifle and transform your shooting skills into…[/h] [h=1]Computer-Like Accuracy…[/h] [h=1]Instantly![/h]
It’s easy to use your new Reflex Red Dot Sight. Just put the dot on what you want to hit and squeeze the trigger.
Just like a highly trained SWAT sniper or spec ops soldier… you’ll be sending hot lead down range with SURGICAL PRECISION… in practically no time at all!
Unlike laser sights… which work great in low light conditions… but not so great in broad daylight… your new Reflex Red Dot Sight works in ANY light.
And you can choose whether you want the reticles and dot either red or green.
Here’s why this is much more effective… and much more ACCURATE than an iron sight:
It’s much less strain on your eyes to look at the Reflex Red Dot Sight… instead of looking down the barrel of your gun to try and focus on an iron sight.
All you need to do is look a few inches from your eye to see the reticle and dot… then place the dot on your target.
Then… every single time you squeeze the trigger… you’ll start placing shots in the EXACT spot where you point the dot.
It’s that easy!
Old Jan 5, 2018 | 05:52 AM
[h=1]MCG REFLEX RED DOT SIGHT[/h] [h=3]20/20 Sharpshooter Vision, Even if You Wear Glasses[/h]
Even better…
[h=1]The Reflex Red Dot Sight[/h] [h=1]Fits almost any gun![/h]
As long as it has either a Weaver or Picatinny rail, you can mount your Reflex Red Dot Sight… in only three minutes or less.
It’s so simple a child could do it. Detailed instructions included.
Order today and everything you need to mount it… all the tools and batteries… are included FREE!
Weaver Rail
Picatinny Rail
[h=1]Here’s What You Get When You Order Your New Reflex Red Dot Sight Today[/h]
[h=4]My Crisis Gear Reflex Red Dot Sight[/h]
[h=4]Accessory Kit[/h] You’ll be able to mount your sight in only minutes. It’s quick, simple and easy!
You can make battery changes in only SECONDS!
We include instructions on how to dial this in for PERFECT accuracy!
[h=4]Battery[/h]
Everything you need to start using your Reflex Red Dot Sight is included… no extra assembly or parts needed!
Old Jan 5, 2018 | 05:53 AM
But that’s not all. When you order today, you’ll also get…
[h=1]TWO BONUS GIFTS[/h] A $29.98 Value… Yours FREE!
BONUS GIFT #1
[h=2]Free Splatterburst targets[/h]
Mount your Reflex Red Dot Sight and then use these targets to dial in your sight to PERFECT accuracy using these two high contrast, highly visible targets.
But that’s not all. Take advantage of this lowest-ever price today and you’ll also get…
BONUS GIFT #2
[h=2]Free Shipping • $9.99 Value[/h]
However… I want to put EVERYTHING in your favor.
So I’m putting all the risk on my shoulders… because you’re protected by our…
[h=1]100% Risk Free[/h] [h=1]60-Day Guarantee![/h]
I know that once you try out your Reflex Red Dot Sight, you’re going to be THRILLED with your IMMEDIATE newfound shooting accuracy.
I want you to FEEL GREAT about your decision today. That’s why I’m also offering you the most generous guarantee in the business.
As soon as you get your new Reflex Red Dot Sight… follow the simple instructions and mount it on your gun.
Next… try it out. I want you to PROVE TO YOURSELF that the Reflex Red Dot Sight can improve your accuracy almost INSTANTLY… without any additional training.
AND… you can relax and try it out a full 60 days… two whole months… completely risk free.
If you’re not ECSTATIC because you’re hitting more targets than ever before… simply contact us and…
[h=3]We’ll Refund Every Single Cent of Your Purchase Price![/h]
You’ve got everything to gain and nothing to lose. That’s why I want you to jump on this special “lowest price ever” offer and try it out right away.
In no time at all you’ll have laser like accuracy… with almost any kind of gun.
Normally, you could expect pay as much as $120 for a hardcore piece of military technology like this.
And it would be worth it to feel confident that you can hit any target… at almost any distance… under ANY lighting conditions.
Although when you act today…
[h=1]It’s Yours At The Lowest Price EVER![/h]
When you order today you’ll get the MCG Reflex Red Dot Sight… with two FREE Splatterburst targets… FREE shipping… and our 100% RISK FREE 60-day guarantee… for only $39.95 each!
[h=3]But you need to act FAST.[/h] Because like I said earlier… with this LOWEST EVER PRICE… and the limited inventory… I can’t guarantee how much longer we’ll be able to make these available at this price.
And if you miss out now you might have to wait 4 to 6 weeks while we restock before you can place another order.
So order right away so you don’t run the risk of missing out.
[h=1]1 FOR $39.95[/h]
Your Order Today Includes
1x MCG Reflex Red Dot Sight
1x Accessory Kit
2x Splatterburst Targets
Free Shipping
ADD TO CART
60-Day Satisfaction Guarantee
Order Securely 24 Hours a Day, 7 Days a Week, 365 Days a Year
[h=1]2 FOR $79.90[/h]
2x MCG Reflex Red Dot Sights
2x Accessory Kits
4x Splatterburst Targets
Free Shipping
ADD TO CART
[h=5]Highest Savings[/h]
[h=1]3 FOR $119.85[/h]
3x MCG Reflex Red Dot Sights
3x Accessory Kits
6x Splatterburst Targets
Free Shipping
ADD TO CART
710 Century Parkway, Allen, TX 75013 - 1-888-509-1175
Home | Privacy Policy | Terms Of Service | Contact
Guns & Ammo
Jan 2, 2017 03:09 PM
Oct 24, 2016 12:31 PM
kingrabbit
Jun 24, 2008 11:17 AM
Ghettopoptart
Aug 23, 2007 02:33 PM
maverick1090
Dec 20, 2006 03:56 AM
