For the LT1 guys
Old Jul 2, 2003 | 07:38 AM
Modular Matt's Avatar
200 SHOT
Default For the LT1 guys
OK Just wanted 2 let ya know that i My brother has a Brand New comp cams 306 FS still in the box and bag that it came in.asking 150$ let me know whats the deal oh no thats not a deal thats a steal
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Old Jul 2, 2003 | 03:34 PM
ZDriver96's Avatar
That is a steal.
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
Old Jul 2, 2003 | 10:14 PM
BlackZ28's Avatar
ppssshsshhhhhhh
just the cam or springs and rockers too?
Old Jul 3, 2003 | 07:48 AM
200 SHOT
Just the "cam" the cam is 250$ ne wi think so 150 bucks is cheap i think
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Old Jul 3, 2003 | 09:16 PM
BlackZ28's Avatar
ppssshsshhhhhhh
why doesnt ur bro need it anymore? i checked out his ride a while bak. its a nice setup and nice ride!! i really want to get the cam, but my car is throwing misfiring codes and is stuttering pretty bad in the first couple gears, so i gotta find some time to open the hood and see wtf is goin on
Old Jul 15, 2003 | 09:20 PM
Sneakin Deacon's Avatar
PSSHHH x2
what are the specs on it, i was lookin at a 305 and liked it cause i think it would go good with the stall. and is this everything that would normally come with it if i ordered it from racenet/summit or osmething like them?
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Jul 22, 2003 | 10:01 AM
SnkEatr's Avatar
Recovering Stroker Addict
Kenny that is the same cam i have in my car, 232/244 @ .050 544/577 with 1.6 Rockers 112 LSA make that bird sound like my Z with some good heads it will make some good power. If you do buy a cam like this you better put some serious springs in there as well, stock springs will bottom out and break stuff.
Local SEO
Old Jul 22, 2003 | 03:10 PM
200 SHOT
oh sorry i didn't get back 2 ya but anyways SnkEatr helped ya out and the cam is still FS and uhh ill take $125 for the cam
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Old Jul 22, 2003 | 05:43 PM
PSSHHH x2
damn, im not sure if i can use it or not... i was looking at the 305 because it would fit in well with my 2400 stall. the 305 is 220/230 .510/.510
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Jul 22, 2003 | 08:54 PM
Gus's Avatar
Gus
hmmm....what all would I need to run this cam in my stock lt1? I might be interested.
