Help me. Clutch bleeding 2000 camaro
Old Oct 7, 2010 | 10:26 AM
fordhottie86's Avatar
fordhottie86
Default Help me. Clutch bleeding 2000 camaro
Oh geez someone help me with this.
I have no clutch pedal I crack the bleeder & pump like brakes etc. nothing happens any ideas fluid doesnt move in resivor.
Ls1hunny
Old Oct 7, 2010 | 12:35 PM
dewey04's Avatar
your camaro has a small ristrictor in the clutch line from the factory you have to open the bleeder screw press down the pedal close screw then relase the pedal repeat untill fluid does not have air in it. Do not the resivor go empty you will have to do it all over again.
Old Oct 7, 2010 | 01:37 PM
J@meson's Avatar
Resident Ginger Kid...
I suggest the same thing and if you have time to buy this, TICKshift.com - Quick Shifting Six Speed Perfectionists scroll to the last one, speed bleeder. You will need 2 people to do it without it, made doing my clutch much easier as its a one way valve. Just open it and stick it in a can of brake fluid and pump away.
2005 Joe Gibbs Silverado # 0396
1988 Monte Carlo SS 5.3/T56 and too many mods.
2003 Honda 954RR
Old Oct 8, 2010 | 10:11 AM
03GSXR750's Avatar
Project Pat
my also want to check your slave cylinder to make sure that its not leaking or blown. I know on my old 240 that when it blew i had no clutch pedal and couldnt shift.
Old Oct 11, 2010 | 07:47 AM
HeavyChevy3800's Avatar
405hp=SLOW
If no fluid is moving when you pump the clutch and crack the bleeder it sounds like the clutch master cylinder isn't working.
Old Oct 11, 2010 | 12:09 PM
J@meson's Avatar
And if thats the case go to the same website I posted and buy a Tick Master cyl...
2003 Honda 954RR
