My Project DD Sierra Build thread
Old Jun 14, 2009 | 10:58 AM
93LowBody's Avatar
TR Balla Donor Supreme
Default My Project DD Sierra Build thread
I recently got my first GMC, I traded my 92 Mazda Miata for a 97 GMC sierra.
It has a long list of mods currently done.
As i got it,
Transgo HD2 shift kit with corvette 3-4 servo
Hypertec Tuner III
Hooker long tube headers
Custom 2.5" dual exhaust exiting the passenger side of the bed in front of rear tires (professionally installed) w/ o2 sensor eliminators
Eaton locker w/ 4.11 gears (for towing, I used to tow 2 quads to races) 3-core aluminum radiator
Electric cooling fan
Jet performance Mass Air sensor for cold air intakes
Casper electronics WOT sensor
FullSizeChevy forums IAT resistor mod
MSD 8mm wires
MSD blaster coil
Bosch 4 iridium plugs
Accel high performace cap and rotor
K&N FIPK
Optima yellow top battery
3/4" lowering kit
17" Cragar soft 8 wheels (OE 15" wheels, and a set of 15" cragar soft 8's also included) w/ 255/40-17 fr and 275/40-17 rr tires
March underdrive pulley kit
high amp alternator (100w)
4-hi painless headlight kit
new belts and hoses
180* low temp thermostat
SS brake lines
fresh brakes
White gauge background w/ led lighting
LED interior lighting (white and blue)
Smoked 3rd brake light w/ led strip and led bed lights
I have added a headunit, And a pair of 12inch subs.
My plans are to put a cam, build the transmission, Put nitrous on it, and fix all the body work.
Since im cheap and dont wanna pay for it to be painted im thinking about just getting some of the local graffiti artists to go at it make it look like nothing else around here.
I may re do the lowering set up for a 4/6 drop to get it nice and low then build a blow through box for it.
I have a jet dynamic spectrum tuner for it so i will be posting the hypertec forsale.
here are a few pictures of it i just took with my iphone, ignore the stuff in the bed the scrap yard closed earlyer then i thought.
Then this is my recent post.
Its been awhile since I've posted so i think its time for an update.
In the last few weeks I've made alot of changes to the truck.
I added a Nos Wet nitrous kit, and 2-12s behind the seat with an amp for the door speakers.
It now has a DJM rear flip kit with C-notches, I may change the shackles out to go up an inch or so because its so close to bottoming out.
Since I have the bed off for the C-notches I plan to clean it up and repaint what I can.. I also want to replace the bed but money doesnt allow me to do abunch at once like this so idk how much will get done.
I need to pull the spacers out of the front now to lower it back down so it will match the back.
I have both bumpers off to be smoothed which is taking longer then i planed but will get it done sometime soon.
I have removed the underglow that was on it, also repainted the Gauge trim black.
I really really need to pick up a set of tires for the truck, And since the nitrous is in(haven't used it yet) I plan to pick up a set of Nitto 555R drag radials or MT cheater Slicks in 325/50/15 for track tires.
This is the only picture I took with the bed on, before the C-notches.
My buddy cutting for the notches.
C-notch in( yes the bolts are that way for a reason)
Working on the frame as I type this.
2 coats of a rust converting primer, 2 coats of self etching prime and soon to be 3 coats of Flat black duplicolor paint.
I ran out of the rust converting primer so I can only do so much right now.. ill get more next weekend.
back to work lol
Well im out of paint to work with this week so its done for now.
Its turned out very well considering how little prep I did.
Thats all for this weekend im done lol.
Old Jun 17, 2009 | 07:25 PM
TheTanMan's Avatar
You can call me Tanner.
Looks pretty nice, Andy. And I'll be getting my permit soon so that's deffinately a plus. But yeah, I'm curious at so much power you're putting out with that?
iSlide.
Old Jul 3, 2009 | 04:28 PM
93LowBody's Avatar
Right now its probably 200-225whp 300-350wtq.. + spray so 300whp 400wtq on spray.
Need to dyno it though to know.
I finally got it sitting like i want.. still a tiny bit low in the back but its the best im doing for now.
Engine bay shot.
and heres the frame before the bed went back on.
Once i get tires on it im gonna start finishing the body work, Pick up a nice big cam for it and do some other things..
