can anyone delete the vats from the ecm
Old Jan 19, 2009 | 07:17 AM
rakoolo's Avatar
Default can anyone delete the vats from the ecm
Can anyone delete the vats from the ecm in a 2001 camaro ss
Ive attempted to bypass the system and is resulting in the same problem.
By deleting the vats program from the ecm will this vats system be completely terminated??
Thanks
LiVn That Crazy Life Right
Old Jan 24, 2009 | 07:37 PM
AccordTypeR's Avatar
try summit, i believe they have a vats elimination kit
Old Jan 24, 2009 | 10:08 PM
???'s Avatar
Capt."Howling Mad"Murdock
yes if you find someone that tunes cars, they can disable the vats in the ecm.
i don't know about your year but the older ones, you could just read the ohm of the resistor in the key and then cut the wires going to the ign and put the same value resistor in there.
