Removal of oil pan on 98 Camaro V6?
Old Jun 4, 2008 | 06:35 PM
VW AUDI MAN's Avatar
Veeduber
Default Removal of oil pan on 98 Camaro V6?
What am i going to have to do to remove the oil pan on a 1998 Camaro V6 so i can get to the oil pump? When the car is at idel the oil light comes on but if you give it a little gas and raise the rpm's the light shuts off.
thanks you for any info possible, Adam
2001 Imola Yellow S4
1998 Ginster Yellow GTI VR6
1992 Red Corrado SLC VR6 stock woookie
1994 Forest Green Corrado SLC VR6 with Vortech Supercharger!
1991 White GLI Jetta 16v in progress
1992 Black GTI 8V mint
1975 930 Turbo Slant noise
And any other car thats at the shop
Unicar Sales VW/Audi Used Parts and Service!
813-935-8847
9109 Lazy Ln. Tampa FL. 33624
Old Jun 5, 2008 | 11:00 AM
HeavyChevy3800's Avatar
405hp=SLOW
The oil pump drive is part of the timing cover. You don't have to remove the oil pan.
Old Jun 6, 2008 | 06:39 AM
Veeduber
Is it easy to get to? Does the timing chain also have to be removed? I havn't looked at the car yet so i don't know what is all in front of it! thanks, adam
813-935-8847
Old Jun 6, 2008 | 09:36 AM
405hp=SLOW
You just have to remove the timing cover. The oil pump is in the timing cover. Five Torx bits hold the oil pump cover on.
Old Jun 8, 2008 | 07:19 AM
Veeduber
Thank you so much for the info. I thought it was going to be a bigger headache then i thought!
Is it a common problem with Chevy's and the oil pump going bad in this motor?
813-935-8847
Old Jun 8, 2008 | 07:38 AM
405hp=SLOW
The oil pump drive is basically a set of gears driven by the crank in the timing cover. They don't fail often.
Old Jun 9, 2008 | 06:44 AM
Theskaterboyanto's Avatar
nothing to do with the oil pan or pump if its the 3800 II motor you have a spun cam bearing the same thing happend to mine two times its a defect in the motor....... i just got a ls3 and put that into mine and a new trany and rear end and its beautiful LOL
Old Jun 9, 2008 | 12:49 PM
Veeduber
Is that the motor that is in this car? or were do i need to look to find out. I don't know anything about these motors, I only know adout VW/Audi motors like non other lol!
813-935-8847
