Drive Shaft not going in!!!!!!
Old May 27, 2008 | 02:36 PM
nmmccasland's Avatar
Default Drive Shaft not going in!!!!!!
Two questions:
1) I just had my tranny rebuild, and I installed it with a new clutch, new throwout bearing, pilot bearing, a slave cylinder. But now the drive shaft wont go in. The tranny shop said it could be the yoke or the bushing. Any suggestions?
2)Does anyone have a step by step on how to bleed the Hydraulics for the clutch. Everything is already connected, I have the fluid, but I got stunp when I tryed to use the a mitty vac to bleed it.
Thanks
How can you tell if your wife is dead?
The sex is the same but the dishes pile up.
