Camaro help
Old Mar 4, 2008 | 04:44 PM
R3AP3R's Avatar
Default Camaro help
hi i have a camaro ss and i am looking for mid price upgrades i have full exhaust system except headers a 58mm throttle body a bored out intake manifold and cold air intake any suggestions would be appreciated thanks
Old Mar 4, 2008 | 04:52 PM
R3AP3R's Avatar
o and its a 97 lt1 ss with a brand new motor
Old Mar 5, 2008 | 06:06 PM
Tiffiny's Avatar
I can fix your bullshit
stall convertor or gear better yet both wake that sucker write up.or a wet nos kit = heads and cam in a bottle
Old Mar 6, 2008 | 06:12 AM
Country Boy's Avatar
can survive...
Pretty much anything that just "bolts on" is good. Get some headers, gears, stall, etc..
Old Mar 6, 2008 | 10:37 AM
ZDriver96's Avatar
What do you mean cold air intake? Did you get rid of the Ram Air?
I would do a brake upgrade on it. The 10.9 Inch rotors with single piston calipers up front would be good if the car were a toyota camry ... but for a performance car they are aweful. Do that first. 20-30 horses in mods you barely feel... but brake up grades and suspension upgrades are very noticeable.
Put some long tubes on the car also. It lightens up the front and also will allow another 25-35 horses or so with your current catback set up. You'll need a custom Y-pipe also. You'll have to buy after market highflow cats too.
You dont have to put cats but you'll smell like gas at stop lights and your car might be louder than what you want. 2 High Flow cats will allow up to about 400 horses before you lose any horsepower. You need 2cfm to support 1 horsepower. There after you'll lose about 10% of any additional horsepower. Also the header bolts are often a pain in the ass. Locking bolts dont work because the bolt has to travel 1/2 a turn before it locks against the header... 1/2 a turn can cause a header leak. I'd use some ARP bolts with a locking washer.. You cant tighten them too much or you'll strip the threads in the head.
At the same time you do the headers, add a 160 degree thermostat and have the PCM reprogrammed for the headers/160stat/180degree fan settings. This way your engine will run cool..
Do the throttle body bypass if you havent done this already. costs 4 bucks or so.
CAGS skip shift mod if you have a 6 speed.
I would do these mods first..
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
Old Mar 6, 2008 | 03:53 PM
R3AP3R's Avatar
Thanks alot im saving up money right now so all these suggestions help alot thanks again
Old Mar 6, 2008 | 09:04 PM
R3AP3R's Avatar
yeah i got a k&n cold air intake a while back ive also been looking at the bored out MAF sensors they run about $125 on ebay are they worth putting one on also how much do the stall converters for the 4l60e usually run?
Old Mar 9, 2008 | 09:27 AM
myltwon's Avatar
Bolt-On 2v GT
don't get a ported maf for an LT1
Old Mar 9, 2008 | 08:31 PM
Tiffiny's Avatar
i can get a deal on them
