How much would I spend??
Old Feb 11, 2008 | 12:33 PM
Clint's Avatar
keyboard hardass
Default How much would I spend??
On new glass for a chopped 1950's Chevy 5-window cab pickup truck?
I have been trying to search all over but I can't find any info about getting glass after chopping the roof by a few inches...
Anyone?
Oh and this is for a potential project, definitely not something I have already
Old Feb 13, 2008 | 07:47 AM
Clint's Avatar
keyboard hardass
Hmm, guess I'm not the only one who doesn't have a clue
Old Feb 13, 2008 | 05:02 PM
???'s Avatar
Capt."Howling Mad"Murdock
wouldn't you chop down the oem glass?
Old Feb 13, 2008 | 05:04 PM
???'s Avatar
from google...
Its gonna have to be cut to fit your application, there are so many variables, in the end you might not end up with a true 3", could be more or less.
What you're going to need to do is make a template of a stock windshield using fiberglass mat, cloth, and resin. Using your stock windshield, wax it a few times, or you can use toilet bowl sealer as a mold release. It needs to be pretty thick so that it has some strength and so that it duplicates the window pretty good. Then, cut it to fit your new window opening (this is done after the chop is completed of course). After you've got it fitting perfectly in there (you'll want to install the fiberglass template with the rubber to make sure it fits), take it, and a new winshield, to a glass shop, they should be able to cut it for you.
Also, the way a '57 window opening is shaped, be sure that you DO NOT bend the pillars at all, because it will screw up the shape of the opening, and will be impossible to make a cut stock window fit.
chopped top – classictrucks.com 1947 - 1959 Chevy Trucks Forum
Old Feb 14, 2008 | 06:03 AM
Clint's Avatar
keyboard hardass
Yeah, I'd seen that link already, but the truck that made me curious didnt come with any glass at all.
Thanks for trying to help though
Old Feb 14, 2008 | 01:04 PM
???'s Avatar
then your going to have to buy oem sized replacment glass, and have it cut down to fit.
cause I'm pretty sure no one has a mold the size you need.
Old Feb 15, 2008 | 04:14 AM
Clint's Avatar
keyboard hardass
Yeah, I was just trying to find out how much that costs to have done
