Anyone know stuff about 92' s10 blazers?
Old Jan 27, 2008 | 07:01 PM
FC3Cturbo's Avatar
eats babies
Default Anyone know stuff about 92' s10 blazers?
My brothers 92' Blazer (4.3L CPI) stalled right after he put the headlights on. The motor was running, tranny was in drive and rolling. I checked all the fuses to see if there was a popped one, didn't see any popped ones. Right now the headlights will not turn on nor the taillights (brake lights still work), the radio and interior lights also are not working. It turns over perfectly normal but will not start, battery terminals are nice and tight. It has not started once before when it was cold out but the headlight problem seems rather odd. Is there another fuse box that I'm not seeing or maybe a fuse I missed? A little help will be greatly appreciated.
Thanks, Tony
Old Jan 28, 2008 | 11:32 AM
Gooser's Avatar
has his own parking spot
Check the relays...could be a problem with the harness too but im not sure. Give shaun a call at All american he can help you more than I. 727-667-9346
Old Jan 29, 2008 | 05:20 PM
Tiffiny's Avatar
I can fix your bullshit
fuseable link ???
Old Feb 2, 2008 | 09:37 AM
FC3Cturbo's Avatar
eats babies
The fuseable links in the front are good. It actually started working again right after my previous post but then 3days later it did it again and has since not "fixed" itself. I am thinking it is a relay aswell.
Old Feb 2, 2008 | 10:14 AM
dart_06's Avatar
minitrucker
can you smell fuel when it is cranking???
98 sDime tu-tu
WTB: project VW or a small 4x4
Old Feb 2, 2008 | 01:40 PM
TJElite's Avatar
Check all the wires at the + terminal and at the alternator. My 91 burban did almost exactly the same thing. One of the wires had broken off (from the alternator, if I remember correctly)...that wire fed most of the constant power stuff in the truck, like radio, lights, and fuel pump. Truck would crank, but not start, since there was no fuel pump.
Toby
Toby Johnson
BlackDog Racing
BlackDog Speed Shop
Lincolnshire, IL
Old Feb 4, 2008 | 03:44 AM
FC3Cturbo's Avatar
eats babies
the rubber cap was off the back of the alternator exposing the wires. I wiggled the wires a little and it started right up. Thanks alot guys for the help.
