s10/cavalier questions...
Old Jan 6, 2008 | 02:07 PM
IThaJokaI's Avatar
Hates cars...
Default s10/cavalier questions...
Ok, not sure if many people on here have bagged/dropped 2nd gen dimes but... I have a 95 and I was looking at the cavalier intake manifold as its a direct bolt on for the 98+ because the TB is removable from the manifold. But in my 95 the TB is part of the plenum(or upper intake manifold) So Basically what I was wondering is if I can use the 98+ cavalier or s10 tb with my 95 and not have to change anything. Im sure the electronics should be close to each other, just wondering if it will work or not. If the 95 ECM wont work, would the 98+ ECM work on my 95 with the 98+ manifold and TB?
Thanks for any resposes,
-Mike
Old Jan 6, 2008 | 06:56 PM
BucWildBob's Avatar
If your 95 is (8th #) vin code W, which is a vortec motor with cpi injection system, nothing is compatible.
Old Jan 8, 2008 | 05:59 PM
IThaJokaI's Avatar
Hates cars...
nope, no w's in my vin... I have the regular 2.2, just the 94-97 TB came made into the manifold but the 98+ was removable. So Im wondering if I can use all 98+ TB shit to get it running...
Old Jan 8, 2008 | 06:33 PM
minitruckinxxxx's Avatar
Im in land o lakes odessa area. I have a fully custom show truck s10 bagged out shaved up.. Need any help with anything lmk i can shave it bag it fiberglass it you name it.
Old Jan 8, 2008 | 07:02 PM
IThaJokaI's Avatar
Hates cars...
Meh... I dont want a mini truck... I just want to know if this will work or not...
Old Jan 9, 2008 | 07:47 PM
IThaJokaI's Avatar
Hates cars...
Bump, still trying to find this out...
Old Jan 11, 2008 | 06:18 AM
IThaJokaI's Avatar
Hates cars...
Nobody has any info on this? I guess Ill just buy them and see what happens...
Old Jan 13, 2008 | 03:56 PM
BucWildBob's Avatar
i dont know much about the 4 cylinders. The 2.2 block didnt undergo any changes that I know of for a long time so I am assuming that it is the same and should work.
Old Jan 15, 2008 | 06:31 AM
IThaJokaI's Avatar
Hates cars...
I know the block is the same. thats not the question at hand. Its all computer realated. The 2.2 block has been the same since the 1st gen cavi. But I want to know if the 98+ throttle body will work with the 94-97 ecu without a reflash or something.
Old Jan 15, 2008 | 12:23 PM
IThaJokaI's Avatar
Hates cars...
anymore info?
