motor not running right
we have a 89 camaro that we just put a motor together for,it was an rs so had the stock 305,the motor in it is a 350 roller with the 305 heads,computer,and efi system,it sounds like it's taking in too much air and runs pretty rough until you have it running for about 10 minutes and then it levels out,any ideas of what it could be or does it just need to be tuned.
vacuum leaks...too much fuel...a 350 with 305 heads...where do you want to begin?
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
true....no but did your dad use biger injectors did he put a biger fuel pump,heres one try adjusting the fuel presure,or just put it on a dyno..maybe you guys have a sensor or a vacum line.intake leak maybe
