02 Fbody valvetrain
took the entire top end off as in got into the lifter valley aswell and none of them looked damaged?
if thats the case, have ya felt around the exhaust manifold gasket (at the head) for bursts of air? sometimes a partially blown exhaust gasket can sound like a lifter tick, and give ghost knock aswell.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
you pulled the lifters out?
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
i've seen one do it after a bad backfire. and another one essentially backed the manifold bolts off causing it to leak.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
it sounds like its only one cylinder, maybe two, so i doubt its normal valvetrain noise, and it is setting the knock sensors off...
kinda off topic, anyone able to take me to the shop tomorrow to get my bearings pressed into the 9" housing?
finally got the gear change done, as well as my comp. reprogrammed....
took it to RevXtreme, and for $75, they reprogrammed for the gear change, deleted my EGR, deleted down stream O2's, and told me that the 'ticking' and knock sensor problems, is more then likely water getting down in the valley and rusting the sensors out.....
