Replacing igntion...
So the time has come to replace the carb and igntion in the Z. I am thanking god that I can finally get rid of that computer controlled junk.
So how complicated/time consuming will it be to install the msd digital 6+ into my monster of a project?
I know that HEI is not a points style ignition, but is it an amplifier style? If so, I don't know which diagram to use, the one for the amplifier style or the one to install into a HEI 4,5 and 7 pin module ignition...
The document is here-> http://www.msdignition.com/pdf/frm23775_6520.pdf
Thanks guys...
This is fun...
Thanks guys...
This is fun...
Hehe,
, I was trying to get it posted fast.
Well, I'm not going to try to hide it, just have it functional and not burning wires or anything. Plus, I want to get this installed so I can use a non-computer controlled carb. It will make things so much easier on me.
Originally Posted by topher469
But even in GM not Ford same thing, shouldn't take more then an hour to have all hooked up and mounted unless of course you spend the time to hide wiring!!
read page 16, hope it is a 4 wire, and follow that diagram- mine works perfect! you might what to thing about a vaccum lock out - it like 5 bucks and it elimates the vaccum can, just set time and forget it, the 6 digital has a start retard!
Pirate Customs
Sound, Security & Style..... anything for your ride
Pirate Customs
I was hoping for a more definite answer
