Help Please
Old Sep 7, 2006 | 07:08 PM
TurboRX8's Avatar
Default Help Please
I bought a 1988 RS Camaro.
Problem is there is a coolant leak and car gets hot if I drive for an hour or more and I have to put more water in it. What I am asking is what could be causing this problem? And how much would it cost to be fixed? Other then this the car runs and drives strong and no other problems at all.
Thanks,
Sam
Old Sep 7, 2006 | 07:57 PM
wmskateteam's Avatar
theres a couple things that could be leaking, just find where the leak is coming from: radiator, hoses, heater hoses, water pump. just look around where it's wet
Old Sep 7, 2006 | 08:00 PM
TurboRX8's Avatar
Ok well all I know right now is that my coolant keeps going down.
Ill check to see tomorrow whats up. I was told it could be a Freeze Plug?
Sam
Old Sep 8, 2006 | 06:00 AM
myltwon's Avatar
Bolt-On 2v GT
could be a leak causing air to get in the lines as well
Old Sep 8, 2006 | 06:32 AM
Sneakin Deacon's Avatar
PSSHHH x2
go rent a coolant system pump....its basically a radiator cap with a hand pump and a guage, pump it up to about 7psi then look on the ground for coolant and trace it
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Sep 8, 2006 | 06:44 PM
TurboRX8's Avatar
Yep Radiator has a small leak. Had a mechanic look at it today... He said try Stop leak and if that dont work Autozone has a brand new radiator for my car for $130 so yea.
Thanks,
Sam
Old Sep 9, 2006 | 05:51 AM
myltwon's Avatar
Bolt-On 2v GT
don't use stop leak, it'll clog up your cooling system
Old Sep 9, 2006 | 03:05 PM
ponchoV8's Avatar
99ProblemsButABitchAin't1
Factory radiator has plastic side tanks, try to get a replacement with metal side tanks if you plan on keeping the car for a while.
What is best in life?
"To crush your enemies, see them driven before you, and to hear the lamentation of the women!" -Conan
Old Sep 13, 2006 | 06:33 PM
TurboRX8's Avatar
Tomorrow im getting my new Radiator installed, Dual Exhaust, and a thermostat. Hopefully that fixes the cooling problem and makes it sound mean
Sam
