nitrous question/audio for my gm. any info helps
Old Jul 3, 2006 | 01:35 PM
chevy94cav's Avatar
Default nitrous question/audio for my gm. any info helps
ok i am woundering here i have a nitrous heater for my bottle. instead of running it all the where to my batt. then to a switch in my cab do u think i could run it to my amp in my trunk? power to memory wire and ground to ground? would this work so my heater would always be on while my amp was on which means everytime im in my car it would be on no extra switch's? pls any info would be helpful thanks....
Old Jul 3, 2006 | 06:00 PM
HybridSS's Avatar
I have fuzzy eyebrows
No...yuo dont want to do that. You need to be able to turn the power off when the pressure gets to a certain psi. On a new bottle it wont take 10 minutes to get the pressure up to high levels. After a while they can get to dangerous levels. Better yet a pressure switch to control the on/off is tghe way to go. Go to www.dynotune.org and check out some of thier heater products. they have a special every once in a while for a complete heater with pressure switche and wiring for $99. Thats the best deal going anywhere.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Jul 3, 2006 | 10:52 PM
chevy94cav's Avatar
ok i'll look into it .... i alrdy have the heater pad but it didnt come with no switch or anything else..... i didnt realize it only takes a few minutes to get up to 1050psi.......
Old Jul 5, 2006 | 02:31 PM
chevy94cav's Avatar
Old Jul 6, 2006 | 02:19 PM
chevy94cav's Avatar
any more info
Old Jul 6, 2006 | 11:39 PM
chevy94cav's Avatar
Old Jul 7, 2006 | 06:42 PM
Jed Z06's Avatar
Do you have a defrost heater in the rear window?
You can grab 12 volts from that, And turn it on and off with the rear defrost switch on the dash!
2002 Z06
Comp Cam, AntiVenom Intake, Crane Dual Valve Springs, LG Street Series Headers, Hi flow cats, BB Bullet Catback, CPU Tuned, Limo Tint, 150 Wet Shot NX, Hurst Short Throw Shifter. 400rwhp, 520rwhp on spray
Old Jul 17, 2006 | 06:08 PM
DANGERANGER's Avatar
Shop Bitch
NO! do it the right way or buy a bag of marshmellows for when it burns!
Old Jul 22, 2006 | 09:06 AM
chevy94cav's Avatar
jed z06 thanks for the info...... and also dangeranger i bought a bag of marshmellows when i put nitrous in my car wont know when u'll need them...
Old Jul 22, 2006 | 09:07 AM
chevy94cav's Avatar
yea ive seen some pictures of a mustang the guy left his heater on over nite morning time it blow his trunk off
