Rough Idle, Tried Almost Everything. Someone Smarter Than Me Help!
Originally Posted by CamaroJoe
Anyone have anything else to add? Are there any good diagnostic tools that I don't already have that I can pick up to help me out?
My 88 s10 does this but only on a cold start.....
Does it get better if you get the RPMS past 3000 then let it go back to idle??
How are you reading TPS voltage and so on? Multimeter or ALDL?
If you don't have it already you may want to invest in an OBD1 aldl cable to connect to your laptop/computer to see what the ECM is doing....
A lot of times the problem can be pinpointed just seeing the data that the ECM is putting out..
I know you said you did propane, but take brake parts cleaner or starting fluid, squirt it along all vacuum lines and listen for a rise in the engine, propane doesn't always do it in my experiences.
You may also have something simple like a bad distributer cap/rotor/module, or a loose wire somewhere.
Also check the MAP sensor, my truck runs like ASS with it unplugged, or faulty....
But the ALDL stuff with winaldl would probably be a quick/easy way for you to determine it for this time, and future times you may have issues.,
-Joe
-Joe
Originally Posted by Mars_302
Id check your coil to see if its leaking, common problem. And Id just get a new IAC, cleaning doesnt always work
-Joe
-Joe
pretty sure its not your IAC or coil..
you say the EGR is blocked off but is it by a plate or just unpluged the vac line to it?
also can you drive the car? how does it run other than the idle?
either way love the 91,92 z28.. still have a 91 myself.
ok stupid question but did you notice the unplugged hose over the driver side valve cover in the pic? i accidentally forgot to cap a hole on the throttle body when i removed a hose in favor of a breather and was about crapping my pants when i was getting an erratic idle and oil pressure. are you sure that the vacuum lines are hooked up in the right place?
The EGR is blocked off by a plate of aluminum and RTV sealant. The vacuum port for it is blocked off at the plenum. I had thought that it may have been the cause of my rough idle and when I went to get a new one all the parts stores needed to special order it. I didn't have time so I blocked it off.
There is no unplugged hose over the driver's side valve cover. There are only three hoses on that side. PCV, Brake booster, and AIR system hoses. All three are properly connected. Am I missing something?
The car runs pretty decent above idle as far as I can tell, but then again I am judgeing that against back when I had two bad fuel injectors, a bad fuel pump, and bad plugs and wires. There is still some hesitation sometimes, but I've encountered worse. It seems to rev up fine too, but then again I've never experienced it running "right".
-Joe
-Joe
I'm pretty much at a loss... sounds like you've tried everything.
maybe try unpluging your o2 and see if it runs better.
have you set the base idle? where you ground A and B (same as checking the codes) wait a min or so with the key on but not running. then unplug the IAC and the set timing plug thing, then start the car and set the idle for 450 rpm's (500rpm"s for an auto trans).... not sure if it will help much be its something free that can't hurt either way to try.
-Joe
-Joe
