LS1 carbed?
Originally Posted by flynbrian
Do a search on google, it is real easy to make 500hp with the carb kit, valve springs and good cam, then lay the spray on top of that, and your notch will fly!!!
Originally Posted by 2kSnakeater
the real question is, why would you want to?
If you want carbed get a 454-502 Engine
yes you can carb an LS1, i was just reading my summit racing order book today in class and they just came out with new intake manifolds and everything else so that you can carb an LS1... its not a dumb question, i was wondering it 4 a while myself...
the only reason you would go with a big cube motor is to keep the revs low, and lots of torque. thats the key to a long lasting engine though...dont make the engine perform at its limits...get a light ass chassis (rx7, 240, fox, miata, civic, s2000 etc etc) and you dont need gobs of power...a mildly cammed 377 with some decent heads, nice converter leaving off a TB could put you reliably in the mid low 10's, not having to spin over 6k and letting you be cheaper on parts if you wanted.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
