305-350 TPI Intake
Old Apr 8, 2006 | 08:13 AM
Civichik05's Avatar
no more imports for me
Default 305-350 TPI Intake
What would I need to change to convert a 350 to TPI, using the 305 TPI parts? Do the intakes still mount differently on the heads? I was thinking just find a 350 intake, and the 305 TPI FR's and injectors should be ok right? Thanks for any help in advance.
Old Apr 8, 2006 | 12:40 PM
Civichik05's Avatar
Already found out. You can use the TPI setup, and you have to replace the intake.
Old Apr 9, 2006 | 04:38 AM
Jaysz28's Avatar
There was only one difference between the 305 and 350 TPI cars, and that was the injector size. 19 lb for the 305, and 22 lb for the 350 cars. TPI was designed for the 305 really.
-jason
Old Apr 9, 2006 | 07:10 PM
Civichik05's Avatar
no my question was the intake itself I know older pre TPI intakes mounted to the heads differently and the bolt holes don't line up between the 305 and 350. I just wasn't positive if it was the same for TPI Engines which it is.
