350 engine need help
Old Sep 27, 2005 | 08:35 AM
88stang5.0's Avatar
00 Yzf R1
Default 350 engine need help
Ok i went muddin a couple of weeks ago and got some water in the engine. no biggie, then afterwards it started to mis fire. so i was rompin on it and then it made a little noise not sure on the noise because i didnt hear it.well now it started to have a little knock and blow alot of white smoke out of the driver side exhaust. so i went and replaced the head gaskets and rod bearings because 1 was spun. started the truck back up and still doing the same thing with the smoke and missing but no more knock. what would cause the smoke if i have brand new head gaskets on? im lost
Old Sep 27, 2005 | 08:53 AM
F*r*a*n*k*e*i's Avatar
White smoke is oil. How are the valves? Maybe you ate a stem seal and it's pissing oil into the combustion chamber? Pull the plugs, are any coated in oil?
Old Sep 27, 2005 | 09:17 AM
Suicidal Racing's Avatar
Has V.I.P in HELL!
frank,white smoke is water not oil,blue is oil and black is gas.u might of cracked a head.did the truck over heat real bad at anytime during when all this happend.are they steal heads or aluminum?
Old Sep 27, 2005 | 09:49 AM
You can tell the difference between white smoke and blue smoke? I can't, they both look white to me.
Old Sep 27, 2005 | 12:07 PM
Guado's Avatar
What can Brown do for you
You have bent a rod slightly if you got water in the engine if you are still getting the knocking noise. Also does the white smoke have a blueish gray tinge to it? If so it would be oil.
-Eddie
Old Sep 27, 2005 | 03:44 PM
Country Boy's Avatar
can survive...
The smoke sounds like a cracked head. Please clearify on the color of the smoke though. Is it pure white or is it bluish white?
Old Sep 27, 2005 | 07:59 PM
Guado's Avatar
Also does it have that sweet nasty burnt oil smell?
-Eddie
Old Sep 27, 2005 | 08:54 PM
???'s Avatar
Capt."Howling Mad"Murdock
damn........
helpful mods, never seen those before.
good work guys
oh and i'm going with the bent rod guy. if it was spun after you sucked up water.
Old Sep 28, 2005 | 03:49 PM
can survive...
Originally Posted by ???
damn........
good work guys
Thanks Thats what were here for. Ill help when I can.
Old Oct 1, 2005 | 01:17 PM
88stang5.0's Avatar
00 Yzf R1
yea i think it is kinda gray. but there are no bent rods because i changed all the rod bearings and there is no knock but still the smoke and when the engine is warmed up it has 0-5 psi oil. also the engine is still missing as well. i think this is all due to some shot rings on one of the cylinders i think number 7 because in the dark that header glows red. well thnx for the help guys
