What are popular mods for GM Engines?
Old Apr 14, 2005 | 04:24 AM
DaTruth's Avatar
Camera Car!
A bunch of good information... Keep it coming...
Single Toyota Supra Auto, Twin Turbo C5 FRC, and Chevy Duramax!!
My email:
vince99frc@gmail.com
Old Apr 14, 2005 | 03:09 PM
Rolling Thundah's Avatar
Originally Posted by ZDriver96
Turbonator????
and Tornado!
Old Apr 14, 2005 | 03:10 PM
Originally Posted by Mars_302
How about replacing those window motors once a year or having to drop everything in the ass end of the car to do a fuel pump, or have a water pump sit of the distributor so when it leaks the car fucks up........
at any rate.....
L98 really need a better intake. Ive known ppl that ahve ported stock ones and gotten decent times, but a better intake is not cheap either. My boss orginal combo for 88 vette was a 383 stroker with self ported L98 alumn heads/intake/factory headers with a cam, roller rockers, throttle body, other few bolts on with DRs was a 12.2@108 I believe. This was back when lt1 were still fairly new and strokers werent even the big rage yet either.
l98's should use the lt1 intake , 35 hp gains.
Old Apr 14, 2005 | 03:31 PM
JuicedSS262's Avatar
Emeritus
I allways found that just a teeny tiny bit of good ole Nitrous Oxide wakes them bad boys up the best.
Old Apr 16, 2005 | 03:44 PM
Jakethesnake's Avatar
Bombs over Baghdad...
vortec ysi blowers
Proud OIF/OEF Veteran and still serving
Old Apr 16, 2005 | 05:35 PM
ZDriver96's Avatar
maybe thatswhy mine doesnt wake
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
Old Apr 16, 2005 | 06:54 PM
  #17 (permalink)
Sneakin Deacon's Avatar
PSSHHH x2
snails and sulfuric oxide (correct term?) are the 2 goodies i like. seem to work with EVERYTHING
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Apr 16, 2005 | 09:05 PM
  #18 (permalink)
NXz28's Avatar
TR Balla Donor Supreme
Originally Posted by formula69
HEADS/CAM WORK:
Lt1s respond very well to even slight changes in the cylinder heads. anything from a freshen up (3-4 angle valve job, pocket port) to a full out port of the stock heads will net you great gains if matched correctly with a cam. up the lift with some 1.6 rockers and your set. i know people who have got these motors in the upward range of 7k rpms. as for aftermarket heads, afr makes some good deals ranging from like 185cfm to 225-230, also edelbrock, trickflow, and the all popular LT4 heads are available. As for cams, the most popular off the shelf cams are the lt4 hotcam and cc305 (pretty mild) to the cc306 and GM847 (heafty) a few guys like joe overton and lloyd elliot make customs that are pretty stout.
Stock LT1 heads flow right around 200-210cfm and peaking around .500 lift. The 180, 195, 210, 215 numbers for the AFR heads are the intake port volume, not cfm numbers.
Old Apr 23, 2005 | 12:29 PM
  #19 (permalink)
trigger's Avatar
Default mods
well, since I'm about to do my L98..
TPiS MiniRam Intake - this is a single piece intake/manifold WITHOUT runners.
52mm Throttle Body
Custom Intake
30# Injectors
Heads
Cam
Pistons
Fresh Stock Block & Crank
The best thing for an L98 is a new intake.
Dwayne Anderson
Old Apr 23, 2005 | 12:49 PM
  #20 (permalink)
Dead Hooker's Avatar
Originally Posted by DaTruth
I am talking about everything from the basic GM 350 4 bolt main crate engine to the current LS7. I want to know what works for L98's, LT1's, LT4's, LT5's, LS1's, LS6's, LS2's, LS7's, etc.... If you can give common aftermarket heads, cams, lids, filters, throttlebodies, etc.. I get asked these questions all the time. I am sure we have a wealth of knowledge out there. We just need to share..
Isn't that a little bit like asking..."Will someone please summarize quantum physics in 1200 words or less please????"
But let me try anyway......
The more it costs and the neater it looks, the beter it'll work.
