those knowledgeable about LS6 heads
Old Apr 4, 2005 | 01:59 PM
Surfnerv89's Avatar
VTEC rocks
Default those knowledgeable about LS6 heads
How much machining and polishing work goes into a stage II LS6 head. What I'm trying to ask is how hard it would be to machine by oneself. My dad owns and runs a machine shop with many CNC machines. He said it wouldn't be hard to do. What exactly would need to be done. Does anybody have stock numbers, and after numbers of the intake and exhaust ports? What else would need to be opened up besides the i/e ports? If I did a h/c I would be looking for 450+ rwhp with a 23x/24x 600/610 114 lsa cam. any input?
2003 Z06
Old Apr 4, 2005 | 03:23 PM
Country Boy's Avatar
can survive...
I wouldnt touch it. One LITTLE thing can make or break it and I wouldnt want to ruin a $1200 set of heads. Valve job, port volume, port shape, chamber CCs, valve back cut all play a HUGE factor on a head.
Old Apr 4, 2005 | 03:57 PM
Surfnerv89's Avatar
VTEC rocks
Yeah, I was thinking it was harder than I was hoping.
2003 Z06
Old Apr 4, 2005 | 04:42 PM
HybridSS's Avatar
I have fuzzy eyebrows
You can have the heads milled there...thats not a biggie. But the rest is more art than machine work. Or its more specific type machine work to heads. Like a specific machine for doing valve jobs. To use a CNC machine to do porting requires first a very skilled porter to do it by hand...get good results with a port they like...then transfer that info digitally inot the CNC machine. Then the CNC machine cranks out exact copies at a higher rate of speed. But you cant just put heads in a CNC machine and have it port heads. Youd be better off doing it yourself.
Dont let anyone other than a proven shop touch the LS6 heads. Futral, TEA, CNC thats about the only places i would go.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Apr 4, 2005 | 08:08 PM
gator's Avatar
Underdog
what the above post said. listen to him.
1999 Pontiac Trans Am
Originally Posted by 1Bad00SS
What makes you think you could of keep up with me. Have you ever had that car on a dyno?
Old Apr 4, 2005 | 08:31 PM
Dead Hooker's Avatar
Porting heads is easy. Just grab a grinder and make the hole bigger. I do it all the time.
Old Apr 4, 2005 | 08:35 PM
Guado's Avatar
What can Brown do for you
+1
-Eddie
Old Apr 4, 2005 | 09:17 PM
HybridSS's Avatar
yep...i have seen him do it too. He uses a step drill and a chop saw. Comes out reeeal niiice!
Old Apr 5, 2005 | 05:19 AM
can survive...
LMAO... I got metal image of that since I use a chop saw everyday
LOL @ Brandon
ls1_ss
Apr 3, 2005 08:03 AM
HybridSS
48
Mar 31, 2004 10:43 AM
