4.3 valve covers
Old Jan 26, 2005 | 06:30 PM
trk1991's Avatar
Default 4.3 valve covers
O.k. so the 4.3 chevy engine isnt a huge power builder, however, when mine is completed i hope itll be worth the trouble. Any ways deal is; i needed some taller center bolt valve covers for a 4.3 so the full roller rockers im putting on the engine will fit. Lo and behold almost no one sells them, some company out west will make them for 425!! Too rich for my blood, so i bought 4 valve covers for 20 bucks cut the tops off of two of them, cut the sealing ring off the other two, and welded them together, bolts go through perfectly and gaskets seal, however since the engine isnt in the truck yet i may run into problems with clearance with the brake booster, we will see, but if any one else has had this problem, or has a vortec chevy motor and wants to build some inexpensive valve covers, it works!! and best part is you can choose the height! Ill post some pictures if anyone wants to know more.. just thought id let you guys know.
Old Jan 27, 2005 | 07:27 PM
LT4BIRD's Avatar
Sport bike killa
I just got my 4.3 together in my astro. Cam,roller rockers,intake,ported heads and JBA headers. Runs pretty good. Good enough for the rice
Some picks sounds good. I will look forward to seeing them.
Maby we can run when you get that beast together.
4.3 Smack Down!!!!
Formula M6
Old Jan 27, 2005 | 08:15 PM
dsmtuner's Avatar
gotta love the boost
Default hell yeah
no problem! ill work on it, the welds look a little rough, but they will hold oil just fine, ill clean em up untill im happy with them, and ill post a few pics on here.
SVT F150
Old Jan 28, 2005 | 04:47 AM
F*r*a*n*k*e*i's Avatar
Shoulda just took the Vortec heads and stuck 'em on a bigger small block
Old Jan 28, 2005 | 05:42 PM
dsmtuner's Avatar
I thought i'd do something different and build up a big six to run good on the track, rather than shoehorning a sbc under the hood of an S-10 takes alittle bit more in the end, but well see if it is worth it.
SVT F150
Old Feb 7, 2005 | 07:21 PM
LT4BIRD's Avatar
Sport bike killa
How bout them 4.3 pics??
Formula M6
Old Feb 7, 2005 | 07:34 PM
dsmtuner's Avatar
ill bring my camera to the shop tommorow
, and post them later this week, they arent cleaned up yet, but youll get the idea
SVT F150
